Old 11-12-2023, 11:07 AM   #11
hrs1326
Liked 19 Times in 10 Posts
Default Re: Stock Eliminator suspension
I reached out to NHRA and got this response??? Definitely more confused than ever.
" Are you asking if the strut rod can have spherical rod ends; if so the answer is no for Stock Eliminator, They are permitted in Super Stock."
Pat Cvengros
Pacific Division Technical Director
hrs1326 is offline   Reply With Quote
Old 11-12-2023, 11:09 AM   #12
hrs1326
You are good.
SUSPENSION, FRONT
Must retain complete stock front-suspension system as
produced by manufacturer for body used. Lift kits/travel
limiters permitted. Sway bar optional. Aftermarket tie rods with
heim joints permitted. Lower control arm may be machined for
larger shock diameter and mount. Strut rods with heim joints
or spherical bearings permitted.
Electric shocks prohibited.
Where did you find this???
Old 11-12-2023, 12:12 PM   #13
Charles Stewart
Liked 755 Times in 213 Posts
You are good.
SUSPENSION, FRONT
Sorry SSDiv 6 and beware, this portion of the rulebook come front the Super Stock section.
Charles Stewart is offline   Reply With Quote
Old 11-12-2023, 12:38 PM   #14
SSDiv6
Thank you for the correction!
As usual, no common sense!
This is a safety issue and it does not apply to Stock Eliminator?
Old 11-12-2023, 01:58 PM   #15
Charles Stewart
As Henrys Toy signature say: "Respectfully" yours, SSDiv6.
Keep on,
Old 11-12-2023, 05:39 PM   #16
Coleydog
Liked 53 Times in 38 Posts
Aw c mon NHRA get your act together. Nothing is ‘stock’ about stock anymore.
Old 11-12-2023, 09:10 PM   #17
I wouldn't worry too much, just yet. NHRA might change the rule by the time you get your car done.
Old 11-13-2023, 08:39 AM   #18
james schaechter
I thought the string here was about stock. I went back to the NHRA site and found this note in Superstock. In the stock category, there is no allowance for the strut rods with heim joints.
Maybe I missed it ?
You are good.
SUSPENSION, FRONT
James Schaechter 3163 STK
Old 11-13-2023, 08:43 AM   #19
SSDiv6
Maybe I missed it ?
See posting #13.
Old 11-13-2023, 09:15 AM   #20
james schaechter
Ok thanks. I agree. There are some inconsistencies in the book for sure.
