Old 11-09-2023, 08:26 AM   #1
Billy Nees
Default Re: Stock Eliminator suspension
Well, it DOES make it easier to fix "bump-steer".
Billy Nees 1188 STK, SS
Old 11-11-2023, 08:45 AM   #2
Coleydog
Liked 53 Times in 38 Posts
If I heard right, one long time stock racer I talked with said the QA1 strut bar was allowed now on his car (Demon).? Back to square one if not allowed.
Old 11-11-2023, 12:06 PM   #3
SSDiv6
You are good.
SUSPENSION, FRONT
Must retain complete stock front-suspension system as
produced by manufacturer for body used. Lift kits/travel
limiters permitted. Sway bar optional. Aftermarket tie rods with
heim joints permitted. Lower control arm may be machined for
larger shock diameter and mount. Strut rods with heim joints
or spherical bearings permitted.
Electric shocks prohibited.
Old 11-11-2023, 12:14 PM   #4
Liked 5,144 Times in 1,964 Posts
You are good.
SUSPENSION, FRONT
I stand corrected then.
I know, when I was helping out a bit on the Tbolt, about 6-7 years ago, they weren't allowed. That was source of movement that was not good.
Some of you might have noticed a bracket car or two with bad bushings. Seeing the front wheels move back and forth while staging was a REAL safety issue.
Old 11-11-2023, 03:57 PM   #5
SSDiv6
Mark,
You are correct!
It took NHRA some time to understand it was a safety issue, especially after a wheelstand.
As I understand, it was Troy Olsonawski who brought up the issue with NHRA and the actual risk.
Old 11-11-2023, 05:32 PM   #6
Coleydog
Great news, with mine now there is no movement front and back when wheels are in air back to normal height. A lot of time went into fixing that and the bump steer.
Old 11-12-2023, 11:07 AM   #7
hrs1326
Liked 19 Times in 10 Posts
I reached out to NHRA and got this response??? Definitely more confused than ever.
" Are you asking if the strut rod can have spherical rod ends; if so the answer is no for Stock Eliminator, They are permitted in Super Stock."
Pat Cvengros
Pacific Division Technical Director
hrs1326 is offline   Reply With Quote
Old 11-12-2023, 11:09 AM   #8
hrs1326
You are good.
SUSPENSION, FRONT
Where did you find this???
Old 11-12-2023, 12:12 PM   #9
Charles Stewart
Liked 755 Times in 213 Posts
You are good.
SUSPENSION, FRONT
Sorry SSDiv 6 and beware, this portion of the rulebook come front the Super Stock section.
Charles Stewart is offline   Reply With Quote
Old 11-12-2023, 12:38 PM   #10
SSDiv6
Thank you for the correction!
As usual, no common sense!
This is a safety issue and it does not apply to Stock Eliminator?
