#11 |
The farther you go down track, the worse the problem becomes with a spragless. The stator is just in the way.
#12 |
Liked 974 Times in 310 Posts
I'll buy two converters are not the same but,a couple hundreths not tenths apart.
#13 | |
Liked 30 Times in 16 Posts
You just got a hold of a dud, for a head to head with a sprag converter which works decent. I've had a couple duds over the years sprag and spragless. It didn't tell me they're all duds. It's pretty apparent I have a fast spragless converter. I had a fast TCI sprag converter years ago, I should've kept and made spragless. |
#14 |
Mike not trying to be condescending or exclusionary here, but what you do ( not even sure what that is) is not even remotely comparable to about 98% of the cars in this section.
#15 |
I say it's apparent I have a fast spragless converter, assuming whomever reads it, can put two and two together. Not comparatively, and I don't mind you believe the myth on spragless converters but figured it could do no harm to share my findings. 23 sbc 3200 lbs.
#16 |
Liked 880 Times in 311 Posts
No Myth to believe.
Not disputing your testing, just your conclusion I have never had a customer with a Comp car go fast with a spragless. Years ago we did a lot of converter testing with an A/ED. (7 similar A-1 converters) Best MPH and ET was not the spragless. My SWAG is the two converters you are comparing are not built exactly the same. The window or the stator back angle could be something different between the two and your engine/gearing combination likes it. IMHO converters are like twin sisters. They may look alike and be numbered the same, but they are a little different.
Adger Smith (Former SS) |
#17 | |
#18 | |
You won't find a faster 3200 lb 23 sbc in the world with a set of out of the box, off the shelf conventional 23 heads, on a 10 x 28 bias tire. The beauty of it is, the driver built the engine,transmission and setup the gear. That's what I do if you're still wondering, drag race. ![]() Last edited by Mike Rietow; 11-13-2021 at 01:14 PM. |
