Old 11-03-2021, 01:24 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default Let's talk converters
In particular 200 metric stuff, 305 in a Malibu. Not positive what is in the car but I do have an ATI that I can't get them to identify for me but.... What does this combo need in real world experience. I am thinking an 8" with around 5600 flash? Am I thinking too loose? I feel like 1-2 shift should be 6100ish and maybe 6400 in 3rd? What is in it now goes 5000ish but it came out of a 350 69 camaro(more inches and HP) Will a 7" be a viable option on this combo? I know the converter companies can answer most of this but I am looking for real world data. Also rear gear is a 513(may go to 5.38) and trans is 275 low
jamie2370 is offline   Reply With Quote
Old 11-03-2021, 05:01 PM   #2
65signet
Liked 48 Times in 22 Posts
Default Re: Let's talk converters
My car is similar to yours, small engine and slower class, i shift close to 7k and finish at over 7k i have 4.88 with a 26 inch tire, i need to send out my convertor i am hoping they can get it to 6k on the flash but i don't know if that is possible because engine does not make much torque.
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
Old 11-04-2021, 11:17 AM   #3
Bobby Lundholm
Liked 127 Times in 49 Posts
You are right on track with 5600.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 11-04-2021, 12:36 PM   #4
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Anyone have experience with a spragless converter? I'm looking at an 8 inch from Broader Performance and have that option. Car is a 68 Mustang 302 with N351 heads and C4. SS/CS legal but run in bracket. 4:29 gears (new gears) 26 in tire for now. Ran to 7000 really fast on it's only pass last year. Want to shift at 6000-6500.
Dale Shearon
68 Mustang 6394
Old 11-04-2021, 12:48 PM   #5
Glenn Briglio
Glenn Briglio's Avatar
Liked 972 Times in 309 Posts
Yes it's slower spragless
Old 11-10-2021, 11:46 PM   #6
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
How much will I pick up, do you reckon if I change to a sprag converter?
I have a 3200 lb 23 degree sbc 3.875 stroke 4.185 bore with a set of out of the box Brodix T1 heads, I did change the springs before bolting them on the engine. 10 x 28 bias tire. All steel roll up windows and chrome bumpers. It has been 1.27 60 ft and runs in the 5's 1/8. Powerglide transmission.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 11-11-2021, 01:29 PM   #7
Liked 5,125 Times in 1,953 Posts
1/8th mile? Not much. Maybe nothing
Old 11-11-2021, 02:52 PM   #8
Glenn Briglio
A tenth and a half slower in 1/4 mile. Stock eliminator 350 chevy with a powerglide Change the convertor at the track same day.
Old 11-11-2021, 08:46 PM   #9
Mike Rietow
Torque converters are like Pro Stock carbs, you can have two identical, one is faster than the other.
This goes for sprag converters too.
I've had sprag converters in this car, one actually ran about the same et as my best spragless. Almost.
Old 11-11-2021, 09:22 PM   #10
Mike Rietow
We run all 1/8 mile in Florida. I did run it to the 1000ft once, went 7.81, same as a big cu inch copo with a LS I was looking at in here few months back running 9.40's.140
