#21 |
Liked 708 Times in 285 Posts
#22 |
Ed Wright 4156 SS/JA |
#23 |
Liked 172 Times in 81 Posts
Have you checked the pressure before the regulator? Most pumps put out about 15 PSI.
You may have a low pressure pump not designed to use with a regulator or the pump is no good. Jim Mantle V/SA 6632 |
#24 |
Liked 240 Times in 112 Posts
Trust the sensor, there isn't a problem. Its 11:1 in high gear. My cars AFR gets leaner as RPM increases an gets richer at each shift. (completely different carb)
Dave Noll, EF/S ,?/SA 6526 |
#25 |
Liked 127 Times in 26 Posts
Jeff did you get a chance to check the volume in a fuel jug for 60 seconds at the front of the car and what volume did you get?
#26 |
#27 |
Liked 280 Times in 139 Posts
#28 |
Liked 110 Times in 29 Posts
Should pump a gallon in 30 seconds. I think you just found your problem.
#29 |
Liked 239 Times in 114 Posts
Its weird that the O2 sensor goes rich , sounds like some work needs to be done to straighten out the fueling of the carb . That being said the carb is using more fuel than can be supplied to it , so the pressure drops . My recommendation is to figure out what's up with the carburetor , but also make sure your fuel system is up to the task . My Q-jet is fed from a BG400 pump through a dash 10 line , and stays right at 6.5 psi throughout the run . Dyno pulls show the A/F ratio varies from 12.8 at 5000rpm to 12.4 at 7400 rpm .
#30 | |
BTW, I was just giving Jeff a hard time. Sorry some of you missed this whole sordid tale, for 5 years ...Check out the build section once in a while ;-)
