Old 01-20-2020, 06:13 PM   #1
Jeff Stout
Liked 704 Times in 281 Posts
Default Question on loosing fuel pressure going down track.
With a quality gauge mounted in front of me on windshield I can watch fuel pressure going down track. What is happening is the pressure is going from 6 lbs to 3.5 lbs. at finish line. I do NOT have a return. I used a good quality pump (dont remember what name brand is in this car) with -8 up to regulator and -8 from reg to carb. My thought is I need a jetted -4 return line at regulator so I can adjust regulator and maintain 6 lbs at finish line. I have plenty of -4 line and would need to only buy fitting that holds jet and my time to run it in car.
Would this help the problem or 3.5 lbs. is enough for a slow car?
Old 01-20-2020, 06:59 PM   #2
Bobby DiDomenico
Liked 101 Times in 52 Posts
Default Re: Question on loosing fuel pressure going down track.
Main thing is to keep the bowl full enough so the jets are covered. What car/carb?
Old 01-20-2020, 07:07 PM   #3
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
You may be having a voltage drop issue. The bigger the feed wire, the better, and closer to the battery, The better you will be. Double check your ground connections, to the pump and relay, too. 10 gauge to pump, at minimum, and 8 would be even better.
If you have a good meter, try to read the voltage, thru the relay, it might show you a problem there.
2894 STK
Old 01-20-2020, 07:13 PM   #4
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Either this or your old pump is just worn out! Jim
Old 01-20-2020, 09:20 PM   #5
Chevy55
Banned
Liked 179 Times in 89 Posts
From Areomotive
At the track, from the launch to mid-track, fuel pressure is steady, but then down track, it falls 2 PSI or more, what’s wrong?
The first thing to be blamed is usually the regulator, but in fact this is a strong indication of a fuel supply problem. If for some reason there is insufficient volume available from the fuel pump to feed the engine, fuel line pressure can drop to the carburetor. Even with a static regulator, a significant drop in line pressure affects flow through the regulator, causing regulator pressure to drop. Do not automatically assume the pump is bad or inadequate, inspect and resolve any supply line issues to the pump, ensure the tank is vented and the vent is functioning, and be sure to check the fuel pump wiring, along with the overall electrical system performance. Finally, if you still have problems, contact Aeromotive for a proper flow test you can perform in the field to verify if your fuel pump is performing properly.
Chevy55 is offline   Reply With Quote
Old 01-20-2020, 09:38 PM   #6
jim morgan
Liked 52 Times in 9 Posts
Or maybe you don’t have a problem, Before all this high pressure,high volume systems
I had a max wedge , Carter electric and manual pump had 6 pounds thru the lights at 2 pounds went 127.5 mph that’s 30 years ago, is your car nosing over, ?
Jim Morgan 1916 , 9916 STK
jim morgan is offline   Reply With Quote
Old 01-20-2020, 10:08 PM   #7
Jeff Stout
Olds 307 large q jet
