Old 05-08-2017, 01:28 PM   #20
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Default Re: Question about fuel injection from a newbie
No reason at all you could not alter tuning by altering the fuel pressure with the factory LT1 injectors. I know NHRA Stock Eliminator racers that do it all the time. Turn the fuel pressure up on an LT1 injector, they have a finer mist as well. That is the point. Higher fuel pressure atomizes the fuel better. That is the reason for higher fuel pressures being used. Better emissions is the main reason. Very small power increase are simply a bonus.
I use injectors from FAST in mine.
I am irritated! I believe what your are saying. It makes sense. But Holley and Fast and some others say it's best to run fuel pressure at what the injector is rated at. On most injectors they are rated at 44.5 so I've got mine right at 45. I will raise the pressure next weekend.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
