Liked 776 Times in 199 Posts
14-15 AF is too lean, I have run FAST for years, I think 30lbs are too small for your LT1 and the reason why when you jack the fuel pressure way up and doesn't change the AF is cause the duty cycle on the 30lb injectors is maxed out. If you look on your dashboard screen on your data logger( if it has the built in data logger and if it doesn't you need one) it will show you the duty cycle in %. And it shouldn't be over 90%
Bret Velde 2003 SS/LA |
