Liked 68 Times in 22 Posts
Using renagade fuel, duty cycle is between 85-90 sometimes. Are there any draw backs to going to a 42lb - 50lb injector?. Not a new car just i am a newbie with fuel injection.
Liked 70 Times in 31 Posts
I just changed my 24lb injectors to 60lb over the winter in my Stock Eliminator LT1. I'm running 45 lbs fuel pressure. From all my research it seems it's best to run the fuel pressure at the injector rated pressure which is usually 43.5 lbs. Some people compensate for too small of injector by increasing pressure. Are you sure your O2 isn't being contaminated with an exhaust leak. Where is your O2 located?
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com Last edited by Darrel Goheen; 05-08-2017 at 01:38 PM. |
Liked 269 Times in 99 Posts
Try replacing you O2 sensor they do go bad due to the leaded fuel. Also location should matter at low RPM but upstairs should not be a big influence unless you have a header leak, make sure there are no leaks at the flanges.
Raising fuel pressure should richen across the map but the ECU does not know it, it's best to add fuel by editing the table. The internal data logger works pretty well for tuning when you indicate an area on the log open tables will show which cells are being used. Tables should have there dashboard closed for this to work. use percentage to make changes: the difference between actual and target O2 in percentage is added or subtracted from number in cell. MOST Important: Always save your base file where you will not delete it. Always save your tune with a unique file name when making changes (facility;date;run#). Much easier to go back where you were if the change did not work get lost which is easy. You should be logging RPM, Fuel, Timing, O2, Voltage at least. Cells are divided in RPM increment usually 500, in the data log select RPM range in high gear for a suspect cell. This will then give you averages on the dashboard below, have the fuel table open with its' dashboard off, cell being used in fuel map will be indicated. Make changes then make another run.
Liked 974 Times in 310 Posts
How many and where are the O2 sensors located? Headers? Collectors sealed to primary tubes? What duration cam at .050?
1 o2 sensor. Located in the collector up close to where headers slide in. Would 42 or 50 or even 60 lb injectors be ok to upgrade to?
Cam 268@50. No exhaust leaks anywhere
I just made a street outlaw pass down the hi way in front of my house with data logger monitoring fuel pressure. I set it at 60lbs, left the line easy and got it in high gear real quick then nailed it. Data show instantly fuel pressure dropped to 25 and stayed there till I let off at 6700rpm. Pressure went right back to 60. Pretty sure its the fuel pump or filter. Since I am new to fuel injection is there anything else that can cause this? I don't think so but again I never thought thought a President would say that its ok for men to go into the womens bathroom. Thanks
Actually the reason they went to 60 lbs.of fuel pressure was that the bean counters got involved in the cost reduction of the package...the horsepower was pretty much already there and it was a lot cheaper to raise the fuel pressure than it was to purchase Millions of bigger injectors to give you the same fuel volume....while a finer fuel mist IS easier to ignite the volume of fuel you are trying to burn is the same because you haven't changed the amount of air ingested and you are working with a specific A/F ratio...any horsepower increase is minimal but when working on 1 engine instead of Millions the cost is easily justified when any increase in power is good.....
D L Rambo....Stk 1300 |
I have not had a lot of time to look at my fuel pump yet but i did turn the pump on and my meter says only 8.38 volts. surely i must be doing something wrong. I touched black to ground and red to hot while pump was running.Same gauge used on battery and battery reads 12.8 volts. what gives?
Liked 16 Times in 7 Posts
Are you checking it with the engine running?
