Liked 524 Times in 84 Posts
Get the Biondo air shift deal and a Turbo Action E Shift Controller. Since you already have the Turbo Action shifter, no use getting rid of that, unless you want to.
#2 | |
Liked 502 Times in 130 Posts
It will be different to launch with my hands on the wheel, like a street car. Thanks Eric
Eric Merryfield 1883 STK |
Liked 223 Times in 73 Posts
Pardon my ignorance, but could someone explain to me what the "clean neutral" valve body is about, and how it leads to this problem?
Since I was planning on a Turbo Action shifter in my build I just want to be sure I'm not setting myself up for a problem. |
#4 | |
Clean neutral is true neutral and effectively simulates pushing the clutch in on a stick car. On my cars/truck is after 3rd gear, so it can be gotten to safely. Concept is it puts less wear and tear on the engine especially lower end, since you are not engine braking it to slow down. The Turboaction shift plate does work if you have the correct one, but its real tough to do it consistently BY HAND, the PPP shifter you can do by hand all day long without issue. When adding air shifting, the air shifter market caters to the vast majority of racers that do not have a clean neutral tranny with their Turbo Action Shifter. If you don't need/want clean neutral it will save you some coin on the valve body, and give you all the options you want for air shift. Or you can pick your color of your PPP shifter and go that route, they are very nice shifters. eric
#5 | |
Thanks, I get the concept. Since I won't be using their clean neutral valve body I presume then I shouldn't have a problem shifting with the Turbo Action shifter. |
Eric I modified mine, used a Biondo air shifter kit and Biondo shift box, it's pretty easy. If you want email or call me 717-357-0657 or bunkmiller@comcast.net
Liked 10,702 Times in 2,228 Posts
Mine looks the same way. Very hard to go 1 to 3. I have never done it. |
