Old 10-09-2013, 04:20 PM   #1
russellauto1
Liked 35 Times in 6 Posts
Default B/PS lt1 formula
I am building a 93 formula with an lt1 for pure stock ihra and I am looking for some opinions on Torque converter and rear gear for that combination. As far as the converter, What stall range should I be in? RPM range of the engine is probally only 5500. Advantages, If any, of having the lockup disc in the converter. The transmission is a 4l60. What rear gear is suggested? I was thinking of a 4.10 or 4.56 with 28" tall tires. . Thanks
russellauto1 is online now   Reply With Quote
Old 10-09-2013, 04:37 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: B/PS lt1 formula
Well you came to the RIGHT Place..
Another person is preparing a 93 Camaro on Class Racer.
Bullet has a Pure Stock Cam and Spring Package that will pass tech.
Even that it is about done by 6000rpm..
I am adding a Yank PT 4200 replacing my Yank SS3800 Converter.
Since my car is driven to the meets they are locking converters.
4.65 gearing with 28 inch would work well.
Would spend the money to get a complete Moser Rear.
The small 7.5 inch rear is ok at stock power levels.
Send pictures of your ride and will post it on the PhotoGallery.
Dan
Old 10-09-2013, 04:49 PM   #3
russellauto1
Are you going to be tuning the ecm also? I think I am going to get tuner cats ?
Old 10-09-2013, 05:09 PM   #4
Ed Wright
Ed Wright's Avatar
The '93 has a removable chip. You would also need a device programmer, and eraser.
Ed Wright 4156 SS/JA
Old 10-09-2013, 06:01 PM   #5
russellauto1
I guess the way I am reading the website, It comes as a package with the burner, Tuner program, and everything that is needed.
Old 10-09-2013, 06:24 PM   #6
Dan Fahey
Dan Fahey's Avatar
Have TunerCat for 94 and 95 PCM..
Also use Byran Herter at PCMforLess.
They have a Dyno Facility near Quaker in Ohio and Farmington in North Carolina.
May want to ping Ed Wright on the Class Racer
D
Old 10-09-2013, 07:03 PM   #7
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
I'd speak to the man Ed Wright who posted above.
He is very knowledgeable from what I have read here.
chris ok is offline   Reply With Quote
Old 10-09-2013, 07:35 PM   #8
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
1993 was the only year that had a 700-R4 (4L60) but not the "e" version. Also the engine did not use a MAF sensor. When did IHRA drop the requirement that the correct part number camshaft be used ?
Old 10-09-2013, 08:08 PM   #9
Ed Wright
Ed Wright's Avatar
They may very well have a package like that.
Old 10-09-2013, 10:11 PM   #10
Dan Fahey
Dan Fahey's Avatar
I do not know that answer on the camshaft.
Mike Baker confirmed the rule in the IHRA book.
And model cam for my Impala SS
D
