Old 10-09-2013, 04:20 PM   #1
russellauto1
Liked 35 Times in 6 Posts
Default B/PS lt1 formula
I am building a 93 formula with an lt1 for pure stock ihra and I am looking for some opinions on Torque converter and rear gear for that combination. As far as the converter, What stall range should I be in? RPM range of the engine is probally only 5500. Advantages, If any, of having the lockup disc in the converter. The transmission is a 4l60. What rear gear is suggested? I was thinking of a 4.10 or 4.56 with 28" tall tires. . Thanks
russellauto1 is offline   Reply With Quote
Old 10-09-2013, 04:37 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: B/PS lt1 formula
Well you came to the RIGHT Place..
Another person is preparing a 93 Camaro on Class Racer.
Bullet has a Pure Stock Cam and Spring Package that will pass tech.
Even that it is about done by 6000rpm..
I am adding a Yank PT 4200 replacing my Yank SS3800 Converter.
Since my car is driven to the meets they are locking converters.
4.65 gearing with 28 inch would work well.
Would spend the money to get a complete Moser Rear.
The small 7.5 inch rear is ok at stock power levels.
Send pictures of your ride and will post it on the PhotoGallery.
Dan
Old 10-09-2013, 04:49 PM   #3
russellauto1
Are you going to be tuning the ecm also? I think I am going to get tuner cats ?
Old 10-09-2013, 05:09 PM   #4
Ed Wright
Ed Wright's Avatar
The '93 has a removable chip. You would also need a device programmer, and eraser.
Ed Wright 4156 SS/JA
Old 10-09-2013, 06:01 PM   #5
russellauto1
I guess the way I am reading the website, It comes as a package with the burner, Tuner program, and everything that is needed.
Old 10-09-2013, 06:24 PM   #6
Dan Fahey
Dan Fahey's Avatar
Have TunerCat for 94 and 95 PCM..
Also use Byran Herter at PCMforLess.
They have a Dyno Facility near Quaker in Ohio and Farmington in North Carolina.
May want to ping Ed Wright on the Class Racer
D
Old 10-09-2013, 07:03 PM   #7
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
I'd speak to the man Ed Wright who posted above.
He is very knowledgeable from what I have read here.
chris ok is offline   Reply With Quote
Old 10-09-2013, 08:08 PM   #8
Ed Wright
Ed Wright's Avatar
They may very well have a package like that.
Old 10-13-2013, 11:21 AM   #9
gbur
Felt a need to apoligize for invading your thread yesterday with my own question GB
gbur is offline   Reply With Quote
Old 10-13-2013, 01:44 PM   #10
russellauto1
Rule book is unclear about rear suspension. Are we allowed to replace the lower control arms and the the track locator bar with aftermarket? And What about Frame connectors ? Also the torque arm. I want it off of the rear of the trans. Are we allowed to build a support for that as long as it is part of the trans crossmember? ? I know I saw a 70s camaro with slapper bars at Norwalk a few years ago so I would assume you can use them for Leaf springs. Thanks Aaron
