Old 05-05-2012, 11:31 AM   #51
Pvt Parts
Pvt Parts's Avatar
Default Re: Recommended Engine Oil ?
Originally Posted by CFMCNC View Post
Oil pressure is the net resistance to flow.the more internal hemorage,the lower oil pressure,the pump rpm is related to idle pressure and the relief valve sets the peak pressure,Volume is the key to addequate lubrication,Nascar Cup at 9500rpms and NHRA Pro-Stocks approaching 11,000 rpm ,both dont see over 50 # oil pressure,high oil pressure is power lost.Blown Alcohol and Nitro engines run 50-70w oil to combat fuel dilution.Bill C.
X2 I remember when we changed to a newly developed low drag pump for our dry sump. It was 4 to 5 HP.
Old 05-05-2012, 11:37 AM   #52
CFMCNC
Originally Posted by Pvt Parts View Post
Ok, here's the low down on oil. If you are a Stock, Super Stock or Comp racer you're goal is to make the most HP without causing damage. Finding that spot with your combination is like finding the perfect clutch set up in a stick car or the perfect converter on an automatic car.
Is there HP is one oil over another???? Yes but just changing oil is not where the real gains are at. What you are looking for is the thinnest oil that will provide the lubrication and cooling properties you need. The real gains are in being able to run the lowest oil pressure with the minimal amount of oil in the pan reducing HP drag on the pump and windage in the pan.
In Ed's defense I will say that Mobil 1 (Extremely low viscosity) with a certain additive (I can't tell you the name) was the best at all of the above that I found. My SS/A Corvette went through the lights with the oil pressure gauge dancing between 40 and 60 lbs. You had to clutch it and shut it off immediately or the oil pressure would go to zero when you hit the brakes.
When I sent my Comp engines back to Houston to be freshened (every 30 to 40 passes) the guys in the shop would drain the oil and say "What the hell is that?" The oil drained out of the pan like water.
BTW, I've never had any lubrication issues with bearings, valve train or cyl walls. Many of the people on this forum could find additional gains of .02 to .03 or more by working this method. It's definitely worth it if you are looking for every .01. Take it slow and check the bottom end.
Exactly what Scott said X2.Bill C.
CFMCNC is offline   Reply With Quote
Old 05-05-2012, 11:51 AM   #53
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Because of the astronimical cost of even aquiring a passenger car 409 block and corresponding large port heads, yet alone the cost of preparing it the best I can for the class ( I'm not really in the income bracket to be playing this game ! ).... I keep re=assembling it with the good 'ol reliable Melling M55HV. The terror of spinning a bearing seems to always keep me on that side !
With the 30 W that I've been using, fully hot oil, I go through the traps at no more than 75 PSI. As mentioned, idle will be around 20-25. At 3000 RPM, it will be at 70.
So, I'm thinkig that while my "high side" may be 15-20 pounds excessive, the drastic change that I see in oil pressure when cooler, is more of a viscosity issue. I was going to go to that real light stuff, but I think that my loose bearing clearances may not get enough "padding", and would simply get washed out because of too much "hemorage" !
err on the side of caution
I've blown this thing up twice now. Once in 2005 because of a broken ARP rod bolt, and a second time in 2009 because of a failed Comp Cams tool-steel spring retainer.
Can't afford to fix it again !
Thanks guys
Remember, I'm there to add to the car count, and take my position at th ebottom of the ladder !
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 05-05-2012, 01:17 PM   #54
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
Originally Posted by HP HUNTER View Post
"Saying your Big Block car is faster than a car with a 6 cyl. is typical bracket racer chump talk" Im going to have to agree with you here. LOL awww. Personally I like to compare Eds 2900 pound 522 inch aftermarket headed, compressioned up car to Grossi's 454 flattop pistoned, 2.06 valved peanut port, Q-jet equiped SS/GTA sunfire, of course I dont think Franks ever had the opurtunity to run out there at Disneyland, like Ed runs at NEGATIVE 2000b feet air, with a 30.50 baro, but somehow Franks 8.70s look pretty good to me right now., what part of the truth dont you like Ed??????????.
Agreed.
Another good comparison is John Clegg's SS/AM, 457 BBC, 3250 lbs, 7.90s, compared to a 522 BBC, 2900 lbs, 8.90s.
3207 D/SA, C/ED
Andrew Hill is online now   Reply With Quote
Old 05-05-2012, 02:01 PM   #55
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
WOW! You guys really take your oil serious around here. I work for Valvoline and we don't think about oil nearly as much as you. Lots, well not lots but some good info in this thread though.
Old 05-05-2012, 10:52 PM   #56
Pvt Parts
Pvt Parts's Avatar
Thanks guys
Hey if you can dial it and drive you have just as good a shot at winning as the next guy. Keep up the good work. I always wanted a '64 with a 409/425 4 speed. Your car is a keeper.
Old 05-06-2012, 08:00 AM   #57
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Typical misinformation from a self promoting chump, here to solicate business.
3144 lbs. and I have NEVER raced in -2000 foot air!
Running 8.90's yesterday with a restrictor plate in 3500 foot air with a 28.9x barometer
Got to go, it's the weekend, I'm racing, something the ebay engine building chump above doesn't do!
Old 05-06-2012, 08:44 AM   #58
Pvt Parts
Pvt Parts's Avatar
Actually we think about horsepower. Oil is just one piece of the puzzle.
Old 05-06-2012, 09:52 AM   #59
HP HUNTER
Liked 373 Times in 129 Posts
Good luck today! really dont need anymore buisness, thank goodness. See Ed we got this 10 inch tire 3250 pound 68 camaro, single 4 bbl NA, Id be more than happy to come back there to "Disneyland" and hand you your *****, but this would heads up, if the moneys right, for one time in your life, just step up. Our season starts next week, heads up, 10 inch tire, all motor racing...........
Old 05-07-2012, 02:40 PM   #60
buzzinhalfdozen
Liked 11 Times in 8 Posts
Dang it! OK Ed I'll bite, you raced @3500 ft. in New Jersey... didn't know there were mountains in that state. Either that or it was 95 degrees 80% humiditry plus your stated barometer. You went 8.90 with a RESTRICTOR PLATE, I knew Nascar used them on the super speedways to slow the cars down, I have to ask.... what are you using one for? NO really this is a legitimate question. So lets recap you state your car is faster than mine..it is, it runs 8 tenths faster with over double the cubes and weighs a whopping 170 lbs. more. Really I fail to see what all the puffery is about. However carry on. Joe
Joe Buchanan SS/BX 3117
