Old 07-06-2011, 04:15 PM   #11
Default Re: Fox body 5.0 subframe connectors
Originally Posted by Bob Pagano View Post
Mark, You made me laugh my ***** off and I aint got much of one left ! Not heard that name for years and years.
Bob, Nostalgia is my business!
I would have had to reinforce the torque boxes on the Mustang if I had run it much more with the stick shift. I just welded up some cracks that were starting for the automatic conversion.
A stick shift will do a lot of damage to those cars. Even a low hp one.
Old 07-06-2011, 05:41 PM   #12
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Talking Re: Fox body 5.0 subframe connectors
Tons of Fun, to bad we did not get to see him against the Giant in a heads up run off
Bob Pagano A/SA
Old 07-06-2011, 09:08 PM   #13
partsbob67
Liked 79 Times in 11 Posts
i would highly recommend a set of battle boxes from wild rides. upper and lowers. fit was great and nice quality. i agree that you can make your own connectors. i bought a pair from griggs racing and they are pretty much a couple of pieces of rectangular box tubing.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 07-07-2011, 10:14 AM   #14
Notch1320
I run the Battle Boxes that Bob stated, and had Maximum Motorsports full length sub frame connectors in my car for years. I now have the Wolfe Racecraft thru the floor type, but only because I ended up doing an 8.50 cage for down the road. I would weld the torque box seams. As stated... stick cars will tear stuff up fast if you don't modify anything.
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 07-08-2011, 10:30 AM   #15
fordteacherguy
Liked 160 Times in 51 Posts
TIm:
I have used UPR full length connectors. Comes with plates for the torque boxes, seat brackets and fit well.
fordteacherguy is offline   Reply With Quote
Old 07-08-2011, 07:27 PM   #16
Tim Ellis
Liked 7 Times in 6 Posts
fordteacherguy.... ZAT you Brian?
Tim Ellis is offline   Reply With Quote
Old 07-08-2011, 11:49 PM   #17
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Originally Posted by dragracer9911 View Post
I ran his all the way back to where the stock frame rail turns to go up and all the way to a similar point in the front.
This is definitely the way you wanna try and go.
Mitch Beri- The Motor City
