Old 07-05-2011, 09:55 PM   #1
Tim Ellis
Liked 7 Times in 6 Posts
Smile Fox body 5.0 subframe connectors
Which subframe connectors did you other Fox body Mustang Stockers use? I'm ready to do it, better late than never. Thanks, Tim
Tim Ellis is offline   Reply With Quote
Old 07-05-2011, 10:34 PM   #2
Chris1529
Liked 70 Times in 29 Posts
Default Re: Fox body 5.0 subframe connectors
I don't think the brand necessarily makes that much different. You are probably going to have to re-route or tweak some brake lines or fuel lines with any kind, and you will have to get all that stuff out of the way anyway to weld them on. I put Jegs bolt on type on my car a long time ago ( probably 10 years) and they seem to work fine. I think it is important to beef up the torque boxes (where the stock control arms mount) as well-especially if you have a stick car.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 07-05-2011, 11:01 PM   #3
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
The best thing I ever did was to make my own and incorporate them into the floor. It makes a world of difference on stiffening the car. Of course it is a lot of work, but worth it.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Sean Marconette is online now   Reply With Quote
Old 07-05-2011, 11:09 PM   #4
I agree .Make your own. They'll fit better and be stronger.
Old 07-05-2011, 11:33 PM   #5
Tim Ellis
Angry Re: Fox body 5.0 subframe connectors
yeah, I found out today I've definitely had some torque box movement
Old 07-06-2011, 11:07 AM   #6
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Those are some good connectors there. They have the seat frame bolt tie-ins.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 07-06-2011, 11:39 AM   #7
It needed them ! Not from me, but from the previous owner , Haystack Calhoun.
Old 07-06-2011, 12:17 PM   #8
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Talking Re: Fox body 5.0 subframe connectors
Mark, You made me laugh my ***** off and I aint got much of one left ! Not heard that name for years and years.
Bob Pagano A/SA
Old 07-06-2011, 12:23 PM   #9
dragracer9911
Liked 3 Times in 1 Post
I custom made my son's front TS 2" x 2" x 1/8". Took about 5 hours on a lift with a tubing bender right there. Unlike the picture, I ran his all the way back to where the stock frame rail turns to go up and all the way to a similar point in the front. I did not cut the floor pan, but I bent them to fit as tight to the follor as close as possible. Then I took a floor jack and a 2 x4 and kept jacking the connector up to the floor. I did weld it completely where it was tight to the floor (most of the connector). My son's car is a stick shift car with more that 2,500 launches @ 5,600 to 6,000 RPM. The torqure boxes are stock, un-reinforced. The car is a low HP car with a 340 HP Ford Crate motor.
dragracer9911 is offline   Reply With Quote
Old 07-06-2011, 04:03 PM   #10
John Quinn
Wolf Racecraft makes a real nice through the floor sub frame connector.
http://www.wolferacecraft.com/detail.aspx?ID=293
Stock - 5013
John Quinn is offline   Reply With Quote
