Liked 9 Times in 2 Posts
I would like to paint my roll cage myself. What products would you recommend for painting? I have heard that Eastwood makes a nice paint. I have also heard that Rust-o-lium applied with a spong brush works well. I will have one week to paint my cage and install my interior when I get it back, so the paint needs to cure within 3 days.
Thank you for the advise, Larry |
Liked 14 Times in 11 Posts
Larry,
I just masked off the glass on my Duster and used Rustoleum gloss black spray cans to do my roll bar. I like the idea of the foam brushes if you have the time for that.
Phil Saran Parker, Colorado |
Larry, we have found the Rustoleum and the foam brush to be the best way with the least mess, usually two coats will do a very nice job. The paints flows nice and dries in about a day. I think spraying turns out a little nicer but takes alot of taping and masking to do a nice clean job
Todd Curtis SS/LA 5571 |
Liked 91 Times in 51 Posts
I also used Rustoleum, but didn't thin it and the foam brush drug the paint around alot. Sort of like streaks. A painter that I know said that I should have thinned it out a little and it would not have done that.
It turned out very nice after a second coat. No primer. I cleaned it with Acryliclean wax/grease remover. |
You may want to consider Rustoleum Hammerite it brushes on and develops its own texture. No brush marks at all.
Bill Edgeworth 6471 STK Last edited by Bill Edgeworth; 04-09-2010 at 12:52 PM. |
I just did a complete roll-cage in a Duster with the Rust-o-leum, Hammer finish black. This turned out super. Get a quart of the paint about $14, will be more than enough, I bought a pack of two small foam rollers, the package is the tray and a pack of two foam 1" brushes. Painting was simple and easy, even the to bars back to the trunk area. Used the foam brushes to get the gusset plates and tight areas then rolled the paint on.
Liked 6 Times in 4 Posts
A few years ago I was told the tech department does not like hammer tone type finishes in either paint or powder coating. While it is legal and will pass, the reason they do not like that rough finish is its too hard to see a crack that could develop somewhere in a tube or at a weld.
#9 | |
How bout some wood grain contact paper ![]() I did mine "the hard way" with etching primer, it bonds really nice, then Urethane with a flattening agent, I didnt get it as flat as aI wanted.
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59) |
Liked 1,580 Times in 582 Posts
VHT makes a roll bar and chassis paint that works great.
http://www.vhtpaint.com/rollbarchassis.html Eastwood also sells a great chassis paint either in spray or brush on. http://www.eastwood.com/specialty-co...sol-14-oz.html http://www.eastwood.com/ew-chassis-b...&parent_id=103 |
