Liked 14 Times in 11 Posts
Larry,
I just masked off the glass on my Duster and used Rustoleum gloss black spray cans to do my roll bar. I like the idea of the foam brushes if you have the time for that.
Phil Saran Parker, Colorado |
Liked 9 Times in 2 Posts
Larry, no primer, I just used oil/grease cleaner, then masked and
it did take about 2 coats of gloss black rustoleum spray paint.
Liked 2 Times in 2 Posts
RustOleum spray here too..works great.
As a side note RustOleum also makes engine enamel,and it too is quality stuff.
Nautilus Racing Last edited by Chris DeGidio; 04-09-2010 at 09:10 PM. |
Larry, we have found the Rustoleum and the foam brush to be the best way with the least mess, usually two coats will do a very nice job. The paints flows nice and dries in about a day. I think spraying turns out a little nicer but takes alot of taping and masking to do a nice clean job
Todd Curtis SS/LA 5571 |
Liked 93 Times in 52 Posts
I also used Rustoleum, but didn't thin it and the foam brush drug the paint around alot. Sort of like streaks. A painter that I know said that I should have thinned it out a little and it would not have done that.
It turned out very nice after a second coat. No primer. I cleaned it with Acryliclean wax/grease remover. |
You may want to consider Rustoleum Hammerite it brushes on and develops its own texture. No brush marks at all.
Bill Edgeworth 6471 STK Last edited by Bill Edgeworth; 04-09-2010 at 12:52 PM. |
I just did a complete roll-cage in a Duster with the Rust-o-leum, Hammer finish black. This turned out super. Get a quart of the paint about $14, will be more than enough, I bought a pack of two small foam rollers, the package is the tray and a pack of two foam 1" brushes. Painting was simple and easy, even the to bars back to the trunk area. Used the foam brushes to get the gusset plates and tight areas then rolled the paint on.
