Old 07-21-2015, 08:43 AM   #1
Ed Wright
Ed Wright's Avatar
Default Re: Air Shifter for Turboaction shifter W clean Nuetral
Originally Posted by Mark Markow View Post
eric go with the precision products. shifter
X2!! Best shifter I ever owned.
Ed Wright 4156 SS/JA
Old 07-21-2015, 01:22 PM   #2
Bryan Worner
Liked 524 Times in 84 Posts
Get the Biondo air shift deal and a Turbo Action E Shift Controller. Since you already have the Turbo Action shifter, no use getting rid of that, unless you want to.
Bryan Worner is offline   Reply With Quote
Old 07-22-2015, 04:03 PM   #3
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Thank You all for the suggestions, I have a complete ACD system which will work with clean neutral, on order and hope to be ready to go with it for Atco. I know how nice the PPP's are as I have one in the dragpak, but the existing turbo action shifter is best for the unique fit in the Dakota and its period correct for this pilot vehicle, former Mopar Performance Team Truck.
It will be different to launch with my hands on the wheel, like a street car.
Thanks
Eric
Eric Merryfield 1883 STK
Old 07-22-2015, 05:51 PM   #4
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Pardon my ignorance, but could someone explain to me what the "clean neutral" valve body is about, and how it leads to this problem?
Since I was planning on a Turbo Action shifter in my build I just want to be sure I'm not setting myself up for a problem.
Dave Muller is offline   Reply With Quote
Old 07-22-2015, 07:25 PM   #5
Eric Merryfield
Dave,
Clean neutral is true neutral and effectively simulates pushing the clutch in on a stick car. On my cars/truck is after 3rd gear, so it can be gotten to safely. Concept is it puts less wear and tear on the engine especially lower end, since you are not engine braking it to slow down. The Turboaction shift plate does work if you have the correct one, but its real tough to do it consistently BY HAND, the PPP shifter you can do by hand all day long without issue.
When adding air shifting, the air shifter market caters to the vast majority of racers that do not have a clean neutral tranny with their Turbo Action Shifter.
If you don't need/want clean neutral it will save you some coin on the valve body, and give you all the options you want for air shift.
Or you can pick your color of your PPP shifter and go that route, they are very nice shifters.
eric
Old 07-22-2015, 07:31 PM   #6
Dave Muller
Originally Posted by Eric Merryfield View Post
Dave,
eric
Thanks, I get the concept. Since I won't be using their clean neutral valve body I presume then I shouldn't have a problem shifting with the Turbo Action shifter.
Old 07-24-2015, 01:15 AM   #7
Larry Miller Jr
Eric I modified mine, used a Biondo air shifter kit and Biondo shift box, it's pretty easy. If you want email or call me 717-357-0657 or bunkmiller@comcast.net
Name:	shifter (478x640).jpg
Larry Miller Jr is offline   Reply With Quote
