#11 |
Super Stock and Stock eliminator are really getting out of hand. This kind of equipment is more like a modified production class. Where is this going to end? The trans case should be OEM.
If I had my way I would have SS and Stock be a foot brake class; no electronics, no wheelie bars, Schubeck lifters, etc. Bring some normalcy back to the two classes. I would have a more thorough list of OEM options from the factory and not dealer installed items to allow the 55-56-57 Chevys back into stock eliminator.
Nelson Kowal Stock 345 |
#12 |
Liked 2 Times in 2 Posts
Hopefully "clutchless" is allowed. There is no et/mph advantage by having one. The major advantage is cost. The cost to run a stick is through the roof and going clutchless alleviates alot of the expense. If there is no performance edge it should be allowed. Might make things more economical to hopefully allow more people to run a stick
#13 |
I agree with Jim. SS/ Modified and Modified Stock are giving up 250 lbs to the automatics and need a clutchless trans to compensate for the weight break. These are the only classes that alow that on the same index. All other automatic classes in Comp and SS have seperate indexes. Besides most stick cars are not using the clutch anyway.
#14 | |
Liked 202 Times in 52 Posts
#15 |
Liked 11 Times in 8 Posts
I didn't see where they were talking about allowing clutchless in stock. As for allowing it in SS I would think it to be a good idea, I'm unaware of anyone who still uses the clutch in a gear change. The primary benefit I see is less trans breakage, shifting a clutch assisted trans without a clutch can certainly be done however it's very hard on the trans. I've tried both combos in my AX car and the E.T. difference is almost none existant. However the durability is considerably different. This may change some racers thoughts on the prospect of running a lever car, it certainly can't hurt. Joe
Joe Buchanan SS/BX 3117 |
#16 |
Well, i still use the clutch on every gear change.
#17 |
Liked 22 Times in 13 Posts
This is pure insanity . For those who don't understand, a clutch assisted box can be shifted without a clutch, at a cost of between .015 and .020 sec per gear change. that is the time spent in neutral between gears. It also limits your clutch tune up as the flair in engine speed applies more counterweight. Do the math, a clutchless will be at least .05 to .06 quicker. Not to mention the ability to tune the clutch in a larger window.
All this does is escalate the cost of racing. Not a smart move given our present economy.What could possibly be the reason for this? Too hard to police? I don't think so, I can show you how to identify the cheaters in a New York min.. I think we need a explaination. The sportsman classes are not the place for highroller experiments. How about stapling the rule book closed for a few years and letting us catch our breath. |
#18 | |
Liked 6 Times in 2 Posts
Wrong on all accounts. A "clutchless" trans is quite a bit more expensive than a clutch type one and both require the same clutch setup. If there was no ET advantage, why do most of the guys abuse their clutch type trannies by not clutching. I don't see where you think clutchless will be cheaper. I don't think they should be allowed in Stock or S/S and Lenco's definately NOT!! The excitement went out of Pro Stock the day they allowed Lenco's.
Dale Posnick |
#19 |
Dale thank you for sharing the video I take it you are in B.C.? We are looking at a new trans now Jerico lists $250 more for a clutchless I hear they hold up better which should cut down on maint. cost. Did you see how hard Schachter had to pull the shifter that shoulder strain will lead to expensive surgery! because we live in Canada with free health care it's of no concern to us. By the way at Indy open tech checked our car for clutchless . Thanx Trevor
#20 |
I'm with you Dale
