Old 10-28-2009, 07:54 AM   #11
njk53
Default Re: Lencos in SS
Super Stock and Stock eliminator are really getting out of hand. This kind of equipment is more like a modified production class. Where is this going to end? The trans case should be OEM.
If I had my way I would have SS and Stock be a foot brake class; no electronics, no wheelie bars, Schubeck lifters, etc. Bring some normalcy back to the two classes.
I would have a more thorough list of OEM options from the factory and not dealer installed items to allow the 55-56-57 Chevys back into stock eliminator.
Nelson Kowal
Stock 345
Old 10-28-2009, 09:26 AM   #12
Kris
Liked 2 Times in 2 Posts
Hopefully "clutchless" is allowed. There is no et/mph advantage by having one. The major advantage is cost. The cost to run a stick is through the roof and going clutchless alleviates alot of the expense. If there is no performance edge it should be allowed. Might make things more economical to hopefully allow more people to run a stick
Kris is offline   Reply With Quote
Old 10-28-2009, 05:15 PM   #13
LB Racing 3179
I agree with Jim. SS/ Modified and Modified Stock are giving up 250 lbs to the automatics and need a clutchless trans to compensate for the weight break. These are the only classes that alow that on the same index. All other automatic classes in Comp and SS have seperate indexes. Besides most stick cars are not using the clutch anyway.
LB Racing 3179 is offline   Reply With Quote
Old 10-28-2009, 06:22 PM   #14
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Unhappy Re: Lencos in SS
Not much stock left in stock.It is really too bad everytime a new rule is allowed we get further away from the class.The end will happen soon enough,then everyone will wonder what went wrong.Not looking to start a internet pissing match just an observation.
Old 10-29-2009, 08:16 AM   #15
buzzinhalfdozen
Liked 11 Times in 8 Posts
I didn't see where they were talking about allowing clutchless in stock. As for allowing it in SS I would think it to be a good idea, I'm unaware of anyone who still uses the clutch in a gear change. The primary benefit I see is less trans breakage, shifting a clutch assisted trans without a clutch can certainly be done however it's very hard on the trans. I've tried both combos in my AX car and the E.T. difference is almost none existant. However the durability is considerably different. This may change some racers thoughts on the prospect of running a lever car, it certainly can't hurt. Joe
Joe Buchanan SS/BX 3117
Old 10-29-2009, 10:07 AM   #16
SuperStockDodge
SuperStockDodge's Avatar
Well, i still use the clutch on every gear change.
ID:	1718   Click image for larger version
ID:	1719   Click image for larger version
SuperStockDodge is offline   Reply With Quote
Old 10-30-2009, 06:43 PM   #17
SSHemi364
Liked 22 Times in 13 Posts
This is pure insanity . For those who don't understand, a clutch assisted box can be shifted without a clutch, at a cost of between .015 and .020 sec per gear change. that is the time spent in neutral between gears. It also limits your clutch tune up as the flair in engine speed applies more counterweight. Do the math, a clutchless will be at least .05 to .06 quicker. Not to mention the ability to tune the clutch in a larger window.
All this does is escalate the cost of racing. Not a smart move given our present economy.What could possibly be the reason for this? Too hard to police? I don't think so, I can show you how to identify the cheaters in a New York min..
I think we need a explaination. The sportsman classes are not the place for highroller experiments. How about stapling the rule book closed for a few years and letting us catch our breath.
SSHemi364 is offline   Reply With Quote
Old 10-30-2009, 07:15 PM   #18
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Wrong on all accounts. A "clutchless" trans is quite a bit more expensive than a clutch type one and both require the same clutch setup. If there was no ET advantage, why do most of the guys abuse their clutch type trannies by not clutching. I don't see where you think clutchless will be cheaper. I don't think they should be allowed in Stock or S/S and Lenco's definately NOT!! The excitement went out of Pro Stock the day they allowed Lenco's.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 10-30-2009, 08:30 PM   #19
tj310
Dale thank you for sharing the video I take it you are in B.C.? We are looking at a new trans now Jerico lists $250 more for a clutchless I hear they hold up better which should cut down on maint. cost. Did you see how hard Schachter had to pull the shifter that shoulder strain will lead to expensive surgery! because we live in Canada with free health care it's of no concern to us. By the way at Indy open tech checked our car for clutchless . Thanx Trevor
Old 10-30-2009, 09:06 PM   #20
SuperStockDodge
I'm with you Dale I'm sorry, but i can't just let my left leg lay there while i'm banging gears. I don't know, maybe it's all about that number and not having fun and going rounds? If you have a clutch pedal stop, correct free play and are coordinated with a manual transmission, i don't see how it can be that much faster (for me) than shifting without the clutch and i can't justify the extra stress/damage on the (clutch assisted) 4-speed. I pull it out of the car enough as it is! LOL
