Old 05-04-2023, 04:05 PM   #1
tolaas
Default Camber caster
What camber caster and toe in should i have on my Camaro 67 with smallblock?
Thank`s
tolaas is offline   Reply With Quote
Old 05-04-2023, 06:56 PM   #2
Chevy55
Banned
Liked 179 Times in 89 Posts
Default Re: Camber caster
Door Slammers: The Chassis Book
by Dave Morgan.
This book will answer all your questions and get you on the right track!
Chevy55 is offline   Reply With Quote
Old 05-05-2023, 08:53 AM   #3
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Camber caster
Thank`s
Good morning to all,
Now I'm not the Subject Matter Expert, but zero toe in/out and as close to zero camber. Bump Steer is another issue that needs to be addressed with these cars and at least 2 to 2 1/2 degrees of caster. If Billy Nees or Bobby Twynam are out there, may be you can elaborate on this question. Reading the " Door Slammer " Book will educate you on the needed specs and why you need them.
Respectfully,
Henry Kunz 1534 H/SA 1969 Nova
Henrys Toy is offline   Reply With Quote
Old 05-05-2023, 09:27 AM   #4
curtis reed
Liked 126 Times in 60 Posts
by Dave Morgan.
Except that is says unavailable.
curtis reed is offline   Reply With Quote
Old 05-05-2023, 02:45 PM   #5
Dave Gantz
Liked 251 Times in 125 Posts
It shows up on eBay.
Old 05-05-2023, 07:22 PM   #6
Chevy55
Banned
Looks like you're right, didn't realize his book wasn't available, I believe he passed away a couple of years ago.
Old 05-05-2023, 10:27 PM   #7
outlaw
outlaw's Avatar
Liked 132 Times in 52 Posts
by Dave Morgan.
I own this book and have read it and I’ve loaned it to a few of my racing friends and most have returned it saying they didn’t comprehend a lot of the stuff in it.That says something for my friends because if you talked to me very long you’d think ld try to read it with the book upside down.
outlaw is offline   Reply With Quote
Old 05-06-2023, 10:20 AM   #8
Eman
Liked 133 Times in 76 Posts
That book will put you to sleep or give you a headache! It's a tough read and not where you look for a quick fix. It takes a lot of time to absorb what he's trying to get across to you and figure out the math.
Old 05-06-2023, 12:34 PM   #9
Billy Nees
Thank`s
Alright, again, you need at least 1* of caster for every 10 MPH over 100. On a '67 Camaro, don't get carried away with positive caster because the more you have, the worse your bump-steer issue will get and I don't know if you have the means to correct it. Early Camaros go negative on camber as the suspension rises so don't be afraid to put 1/8 to 1/4* of positive camber.
Before you start to set your toe, make sure that both tie-rods are equal length and when done make sure again. Don't worry about your steering wheel being centered. If your anal-retention won't allow your wheel to be crooked then you'll have to find another way to straighten it.
IF, if you want to take a crack at your bump-steer, you will more-than-likely need to lower the outer tie-rod either with spacers or by bending your steering knuckle.
IF, if you don't get carried away with positive caster, the bump-steer shouldn't be bad enough to even mess with.
Billy Nees 1188 STK, SS
Old 05-06-2023, 10:29 PM   #10
vette5148
Liked 44 Times in 14 Posts
Don't worry about your tie rod sleeves being perfectly centered-worry more about the centerlink being centered!! I see more cars where people worry about the sleeves and the centerlink is off from side to side. If the centerlink is off it completely screws up the bumpsteer from side to side. One side might not be too bad and the other is way off. I've been doing this for a few decades now and seen a lot of screw ups. The idler and pitman arm should be straight front to back when the centerlink is centered.
vette5148 is offline   Reply With Quote
