Old 04-13-2023, 09:39 AM   #1
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Min assembly weight effect on ET
If you were able to lose 100 grams off your rod/piston weight. How much ET difference would you see? I’ve looked all over trying to find an answer with no luck.
Old 04-13-2023, 10:21 AM   #2
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: Min assembly weight effect on ET
Zero.
Old 04-13-2023, 10:54 AM   #3
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
100 grams * 8 = 800 grams / 1.7637 lbs
Let say that weight is at a 4" radius with an acceleration rate of 2500 RPS.
Stan
Old 04-13-2023, 11:10 AM   #4
MR DERBY CITY
Liked 8,250 Times in 1,542 Posts
It sure won’t hurt …l
Old 04-13-2023, 11:19 AM   #5
Stan Weiss
Stan Weiss's Avatar
That depends on where and how much weight was removed. Is the part now no longer as strong as it needs to be, and it is flexing which will cost you more HP than the weight saving gave you?
Stan
Old 04-13-2023, 11:50 AM   #6
MR DERBY CITY
I have to disagree Stan. I believe the OP is referring to his LT 1 stocker and he is blueprinting the piston/rod combo to achieve the minimum weight spec set by NHRA. I dont believe he is in any danger of weakening or flexing any stocker parts…
Old 04-13-2023, 11:56 AM   #7
Rob Petrie E395
Stan
The bulk of the weight reduction would come from a lighter rod. Production GM rod that has had small end bushed and ARP rod bolts installed vs significantly lighter Manley Rod thats on the approved list.
Old 04-13-2023, 12:10 PM   #8
Stan Weiss
Stan Weiss's Avatar
Then you should be fine. I took it as you were going to lighten the parts you had.
Stan
Old 04-13-2023, 03:28 PM   #9
GTX JOHN
On our small block Mopars less than a hundred.
John Irving
741 Stock
741 Super Stock
Old 04-13-2023, 03:52 PM   #10
Jeff Stout
Liked 708 Times in 285 Posts
I was hoping for a better outcome. Im about 120 grams per assembly heavy. Thats basically running a ninth piston assembly
