Old 04-13-2023, 11:10 AM   #1
MR DERBY CITY
Liked 7,941 Times in 1,520 Posts
Default Re: Min assembly weight effect on ET
It sure won’t hurt …l
Old 04-13-2023, 11:19 AM   #2
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
That depends on where and how much weight was removed. Is the part now no longer as strong as it needs to be, and it is flexing which will cost you more HP than the weight saving gave you?
Stan
Old 04-13-2023, 11:50 AM   #3
MR DERBY CITY
I have to disagree Stan. I believe the OP is referring to his LT 1 stocker and he is blueprinting the piston/rod combo to achieve the minimum weight spec set by NHRA. I dont believe he is in any danger of weakening or flexing any stocker parts…
Old 04-13-2023, 11:56 AM   #4
Rob Petrie E395
Liked 216 Times in 77 Posts
Stan
The bulk of the weight reduction would come from a lighter rod. Production GM rod that has had small end bushed and ARP rod bolts installed vs significantly lighter Manley Rod thats on the approved list.
Old 04-13-2023, 12:10 PM   #5
Stan Weiss
Stan Weiss's Avatar
Then you should be fine. I took it as you were going to lighten the parts you had.
Stan
Old 04-13-2023, 03:28 PM   #6
GTX JOHN
Liked 2,486 Times in 697 Posts
On our small block Mopars less than a hundred.
John Irving
741 Stock
741 Super Stock
Old 04-13-2023, 03:52 PM   #7
Jeff Stout
Liked 704 Times in 281 Posts
I was hoping for a better outcome. Im about 120 grams per assembly heavy. Thats basically running a ninth piston assembly
Old 04-13-2023, 06:33 PM   #8
Kirk Morgan
Liked 80 Times in 44 Posts
I dont know about horse power but it should help the engine accelerate quicker.
Kirk Morgan is offline   Reply With Quote
