Liked 117 Times in 50 Posts
Anybody here race one?
Are they a viable combo without having to mortgage my home? The sedans appear to be natural K cars, and the wagons appear to be natural N cars. The best off the shelf headers I can find so far, is Hooker's funky #2063 ceramic-coated Super Comp 1-3/4"x3" headers, which appear to sweep up and over. Is there any advantage to keeping the 4L60E, for it's 3.06 first gear? I don't think a metric 200 would be in the budget for me. It looks like there are proper 8" converters available for them. Does Global West make Del-Alum front control arm bushings for them? Who makes lightweight front brake kits for them? I found single and double adjustable front shocks from Strange, but nothing for the rear. I'd sure be interested in hearing from anyone that has raced one. Last edited by 6130; 08-07-2021 at 11:40 AM. |
A VERY good combo but IMHO not cheap.
#4 | |
I don't know what you would consider "breaking the bank". You SHOULD get an aftermarket ECU, a GOOD 3-speed trans and you're going to have to fill up the 8.5 rear with GOOD parts or get a 12 bolt. The only place where I could see you "cheaping out" would be with the motor. I don't see the need for a bunch of trick parts to "comfortably run under" the index but you are going to need a competent shop that understands LT-1s.
Thank you. I noticed the 59 horsepower while going through the classification guides.
Liked 409 Times in 113 Posts
PM Corbitt Marshburn on this site . He has built the LT-1 powered wagon and could guide you down the right path.
Joe Huestis "Annie's Song" Racing U/SA 2724 Youngsville, NC |
#7 | |
I just PM'd him. He's been a member here since 2004, but he's never made a single post, so I wouldn't know if he even checks in here anymore. I Googled his name, and found a pic of the black wagon. Is it a class car, or a bracket car? |
Liked 319 Times in 68 Posts
Ditch 4/60LE transmission,will kill you
. Don't even think about it!
Lee Valentine 1661 STK |
#9 | |
Liked 2,361 Times in 558 Posts
It shouldn't be crazy expensive to build a competitive car. It all depends on what your budget is and how much you can do yourself. Last edited by GUMP; 08-05-2021 at 08:53 PM. |
Billy is right,the engine is where you can save. I've built combos I just wanted to see if they were viable using cast pistons,home brewed low drag ring package etc. that weren't much slower than first class stuff. Good basics and preparation does a lot,might not want to run it forever but good maintenance and common sense driving go a long way. Sorry for the long winded response. Good Luck.
