A VERY good combo but IMHO not cheap.
Liked 117 Times in 50 Posts
#3 | |
I don't know what you would consider "breaking the bank". You SHOULD get an aftermarket ECU, a GOOD 3-speed trans and you're going to have to fill up the 8.5 rear with GOOD parts or get a 12 bolt. The only place where I could see you "cheaping out" would be with the motor. I don't see the need for a bunch of trick parts to "comfortably run under" the index but you are going to need a competent shop that understands LT-1s.
Thank you. I noticed the 59 horsepower while going through the classification guides.
Liked 410 Times in 114 Posts
PM Corbitt Marshburn on this site . He has built the LT-1 powered wagon and could guide you down the right path.
Joe Huestis "Annie's Song" Racing U/SA 2724 Youngsville, NC |
#6 | |
I just PM'd him. He's been a member here since 2004, but he's never made a single post, so I wouldn't know if he even checks in here anymore. I Googled his name, and found a pic of the black wagon. Is it a class car, or a bracket car? |
Liked 319 Times in 68 Posts
Ditch 4/60LE transmission,will kill you
. Don't even think about it!
Lee Valentine 1661 STK |
#8 | |
Liked 2,361 Times in 558 Posts
It shouldn't be crazy expensive to build a competitive car. It all depends on what your budget is and how much you can do yourself. Last edited by GUMP; 08-05-2021 at 08:53 PM. |
Billy is right,the engine is where you can save. I've built combos I just wanted to see if they were viable using cast pistons,home brewed low drag ring package etc. that weren't much slower than first class stuff. Good basics and preparation does a lot,might not want to run it forever but good maintenance and common sense driving go a long way. Sorry for the long winded response. Good Luck.
Thanks, guys.
I do like wagons... |
