Old 11-08-2007, 03:50 PM   #1
Real Racer
Default New Mopar Crate Motor
Do you think that there is any chance that IHRA will allow this one? Could be pretty good around 400 factored HP. Fun for sure especially with a stick.
Mopar Performance revives Six-Pack small-block
The 410 Magnum Six-Pack crate engine is available from Mopar Performance
photo courtesy Mopar Performance
The triple-carbed Mopar engine is a mainstay of the muscle car genre, and one that makes fans of all makes and models take notice.
Back in the day, Chrysler offered the three-deuce arrangement only on small-block engines in a limited run of Challenger T/A and ?Cuda AAR models, which were really only offered to the public to homologate the package for Trans-Am racing.
Now Mopar Performance has combined the trio of Holleys with a small-block and added the benefit of more cubes. The 410 Magnum Six-Pack crate engine is based on a brand-new block, which MP claims is a 340 piece rather than the late-model Magnum type most of its recent crates have used. The block is stuffed with a 4.00-inch cast stroker crank, which, when combined with the 4.040-inch bores, creates 410 cubic inches.
The cylinder heads are cast-iron Magnum R/T ?big-valve? assemblies, though they utilize the Chrysler LA-series small-block intake bolt pattern, allowing the aluminum manifold to bolt right up. The compression ratio is a pump-gas compatible 9.7:1 and the camshaft is hydraulic, with 248 duration at .050 and .508-inch lift. The engine comes with an eight-quart center-sump oil pan and Mopar Performance cast aluminum finned rocker covers, but you?ll have to round up a set of carbs yourself (MP has them, too).
Rated for 450 horsepower and 475-lbs.ft. of torque, the Six-Pack crate small-block makes a perfect powerplant for the street/strip Mopar
Real Racer is offline   Reply With Quote
