Old 09-15-2020, 08:21 PM   #1
Jim Hanig
Liked 99 Times in 49 Posts
Default carb
I have a 780 holley carb that has fuel coming through 1 booster, check the float change the gaskets 6 pounds of fuel pressure. the carb run fine till i put it back on the stocker motor. Changed the carb to another 780 it ran fine till i shut the motor down then restarted it ,same thing. Any guesses?
