Liked 48 Times in 18 Posts
Jim if you're talking about dripping after you shut the motor off you just aren't turning your fuel pump off early enough before you shut the motor off in this hot weather. If you are talking about with the engine running either your float level is too high, or your fuel pressure guage is not right
Liked 11,010 Times in 2,263 Posts
Is the mounting surface level on intake side to side?
Liked 227 Times in 138 Posts
Change both gaskets float bowl side and main body side also replace the the 4 bowl screw gaskets and torque the the bowl screws to 35 in-pounds and your problem should go away.
Liked 2 Times in 2 Posts
power valve hitting the base plate screw "boss" in the vac. chamber not allowing the m/block gasket to seal to the venturi surface. this is a common problem with "older" venturi's. check a new venturi an you'll see what i mean..
this is also made worse if you are using the new non-compressible p/valve gasket with a mill'd surface of the venturi as they become closer together. |
Liked 66 Times in 37 Posts
o ring on needle and seat
72 cutlass |
#6 | |
Liked 99 Times in 49 Posts
Banned
Liked 179 Times in 89 Posts
Also check the needle and seat, I've had debris stick in there and prevented it from sealing.
Liked 335 Times in 182 Posts
HSAB plugged or maybe you have the bowl gasket or metering plate gasket installed incorrectly OR you have the wrong gaskets to start with---a symptom of definitely siphoning fuel out
Not sure if you wrote "its solved" but you can run the engine up to about 2500RPM and put a gloved hand or towel over the carb top when the engine has almost died remove your hand or the towel and let the RPM come back up---do this 2-3 times and see if it clears up ---what you are doing is going from vacuum to siphoning and jostling any particles that may been the bleeds or the idle passages--kinda self cleaning or sloshing process by going back and forth
Liked 239 Times in 114 Posts
