The NMCA Technical Department has*approved Ford Performance P/N M-9603-CJN (Air Intake/Box) for 2008 – 2016 Ford Cobra Jet combinations using a 2016 Front Entry Blower in the NMCA Factory Super Cars class. This amendment is effective immediately. Where can I purchase one of these?? Doesn't show searching Ford Performance site.
Thanks , TC
Terry Crow 2012 FS/H |
Liked 10 Times in 3 Posts
Jake Sealey 2507 Stock 2075 SuperStock |
Thanks
Liked 80 Times in 29 Posts
I wouldn't spend much money on this kit.
It does have shortcomings although it can be improved dramatically. |
Liked 1,568 Times in 579 Posts
Call EB Custom Works and speak to Eric.
(516) 780-5039 They are one of the sponsors of this forum. |
Thanks for the info. I will call them. I understand the cost's involved with R&D + supply & demand. $1500 is a lot. I just can't believe with a straight in design like this, RAM AIR , performance gains would not be substantial when perfected. What am I missing? I also know Watson Racing has filled the gaps with innovative CJ parts not available any where else. THANKS.
I seem to recall a similar set-up when the 429 NINGA motor was used in Factory Stock? Picture I saw was one I assume Chris Holbrook had made. Nice design, very custom.
That's simply ridiculous.
What is your goal? What specifically would you like to accomplish with the addition of intake components such as these? |
#8 | |
Liked 2,336 Times in 549 Posts
Low volume items like this are expensive. Especially if they have an OEM part number
#9 | |
Liked 122 Times in 11 Posts
I'm not familiar with this new one but I think it's on the 2019 CJ and that has an aftermarket radiator on it (at least the one I saw did). THis inlet could require a different radiator, I'd at least ask before buying.
Jesse Kershaw |
I have seen two versions of the 429 Ninja air intake, one was aluminum and the other was either fiberglass or carbon fiber. Both of them had the Ford Racing part number ID plate on them.
