Old 07-30-2018, 12:46 PM   #1
Eman
Liked 133 Times in 76 Posts
Default 3rd Gen F body..throttle linkage?
On a 3rd gen F body with a SBC and carb are you using the stock throttle cable? Or are you using an aftermarket cable? or a rod?
Old 07-30-2018, 08:13 PM   #2
REGGIE WINKLES
Liked 39 Times in 9 Posts
Default Re: 3rd Gen F body..throttle linkage?
Stock part and return springs on my gen3 q-jet stocker, zero concerns 🏁
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 07-30-2018, 11:18 PM   #3
Eman
Thanks for the reply. I've been running a stock cable and pedal setup. I broke a cable this weekend so since I have to fix it I wanted to make it as good as I could. Looking at how it broke I believe I need to make a positive stop under the pedal. When it popped I could feel the pedal drop a little.
Old 07-31-2018, 09:45 AM   #4
CJ McDonald 9564
Liked 11 Times in 6 Posts
I use the one that bolts on with the intake bolts with no problems. The older style that uses the rear carb bolts is another option and actually a little cleaner looking setup.
CJ McDonald 9564 is offline   Reply With Quote
Old 07-31-2018, 11:31 AM   #5
Eman
OK, so you're using the factory style cable and bracket?
Old 07-31-2018, 05:43 PM   #6
Hacksaw
Liked 315 Times in 178 Posts
I am using the stock cable set-up. Always make sure the pedal stops on the floor or make an adjustable stop, if you don't, you will stretch the cable and it will fail. I have looked before and could not find anyone that offers a replacement rod linkage to suit these cars.
Old 07-31-2018, 09:45 PM   #7
Eman
Thanks for the responses.
The tunnel width and height would make it hard to fabricate a rod setup, not impossible just hard! I felt the cable pop as I launched and the pedal did drop when it did so I was stretching the cable. I do need to make a pedal stop as pushing hard on the pedal was actually pulling hard on the cable.
