Old 03-16-2018, 03:26 PM   #1
bert powell
Liked 34 Times in 12 Posts
Default Cleaning out the garage
402 BBC Diamond pistons new/unused 4.191 bore .0415/.043/3mm coated top. Will throw in ring set with 4 dyno pulls. $700
JE 396/350 pistons (6), Crower rods 2.200/.927x2.500 (2 new), new pins. Need 2 pistons to complete $500
290 Heads Up heads, one repaired but would replace, with valves $800
TH400 reverse valve body, alum drums, deep pan, locking dipstick, less than 100 runs since new, 30 since rebuild $900
Jesel belt drive BBC 9.8, everything there but would replace belt and seals $500
Jesel belt drive BBC 9.8, excellent with brand new belt $650
BBC 904 Isky lifters excellent condition $500
BBC 904 Isky lifters fresh from rebuild $700
Misc roller cams std bore $150
Alum CSI 168t auto flexplate $60
12 bolt street gears 3.90 $75
Q-jet prepped carbs $300 each
292 head castings, 2 sets $250 ea set
049 head castings $300
291 heads, Ferrera valves, dual springs, need rebuilt $600
215 heads complete takeoff $350
236, 049 and 820 single castings $100 ea
6223 crank std/std nitrided, ex cond $350
454 7416 steel crank need turned $150
454 cast cranks need turned $50 ea
327 sj 1965 block cleaned, needs honed $150
454 block .030 with one sleeve, may clean up $300
454 block std $500
396 block std bore $250
402 block from Hettler engine 4.193 currently, filled, 2 bolt, clean up at 4.200 $150
82-92 camaro plastic headlights, lightweight, new in box $60
Merlin intake, oval port, ported for super stock $400
Quay headers for 82-92 camaro 2 1/8- 2 ΒΌ step, dyno time only $500
New Dana 60 5.57 Richmond pro gear $350
85 camaro ground effects $100
82 camaro factory fiberglass hood, one corner needs minor repair $300
14x32 M/T radial slicks, 35 runs $200
All plus shipping call or text 9 19 9618505
bert powell is offline   Reply With Quote
Old 03-16-2018, 06:21 PM   #2
Bob Lasko
Bob Lasko's Avatar
Liked 186 Times in 55 Posts
Default Re: Cleaning out the garage
interested in the head lights, all four.
Bob Lasko
lasko@optonline.net
Old 03-16-2018, 08:16 PM   #3
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Pm sent
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 03-19-2018, 01:40 PM   #4
bert powell
email sent
Bob Lasko
lasko@optonline.net
Old 03-19-2018, 01:48 PM   #5
bert powell
PM sent
Originally Posted by Chipper Chapman View Post
Pm sent
Old 03-28-2018, 08:30 AM   #6
bert powell
Chipper Chapman PM sent.
Old 03-29-2018, 07:22 PM   #7
66novaguy
Sent you a message
66novaguy is offline   Reply With Quote
