Go Back   CLASS RACER FORUM > Class Racer Forums > Competition
Old 09-06-2007, 10:26 AM   #1
Lentech Automatics
Default Is a Rack& Pinion allowed in SS modified classes??
I have a 71 Maverick that I'd like to campain in SS/BM
It still has the original upper an lower control arms ,shock towers , but we have replaced the steering gear with a rack and pinion.......Is this legal or not ??????I'm getting some conflicting info on this .....Called IHRA tech , they say no problem , then called NHRA and they said shouldn't be a problem but was'nt 100% sure , so he said he'd look into it but I hav'nt heard back yet
IHRA stated " It's OK for the SS modiified classes only "......any comments ?
Thanks,
Len ,
Lentech Automatics
Lentech Automatics is offline   Reply With Quote
Old 09-07-2007, 09:38 AM   #2
Rory McNeil
Liked 1,112 Times in 304 Posts
Default Re: Is a Rack& Pinion allowed in SS modified classes??
Good question, considering that I see later model year Camaros and Firebirds using Ford Pinto racks in STOCK, it would be interesting to see them deny a Ford rack in a Ford car in S/S, wouldn`t you think?
NHRA 6390 STK
M/S 85 Mustang
Old 09-07-2007, 10:40 PM   #3
Lentech Automatics
Makes sense to me in a modified class Rory......but in stock????? , I read the stock section and I don't see how that can be interpreted from the rules
Old 09-08-2007, 05:57 PM   #4
G Schenck
Liked 81 Times in 35 Posts
Power steer cars may be converted to manual as per NHRA rule book.
Greg
G Schenck is offline   Reply With Quote
Old 09-10-2007, 10:38 PM   #5
SPS
Liked 3 Times in 2 Posts
Greg, you are exactly correct. If the car had a rack it can be replaced with a manual rack. If the car had a conventional steering box, it has to keep it.
This was discussed when the truck program came along: ie S-10's with a steering box and Dodge trucks with a rack. Ask any reputable chassis builder.
FJ
SPS is offline   Reply With Quote
Old 11-09-2007, 10:53 PM   #6
71mavlouisville
71mavlouisville's Avatar
Liked 28 Times in 1 Post
The rules allow you to convert to rack and pinion steering in modified. I recently went through this while building a ss modified car in 2005. Travis Miller (NHRA tech Division 3) supervised the build and we contacted NHRA tech. The rulebook then specifiically stated it. In the 2007 rule book it states for RWD a "NHRA accepted front suspension" They accepted it.
71mavlouisville is offline   Reply With Quote
Old 11-22-2007, 05:21 AM   #7
davyjones
what kind of car did you build ?
davyjones is offline   Reply With Quote
