Liked 294 Times in 93 Posts
Putting my 1967 Fairlane back to street condition, 390/320 motor, C4 2.75 transmission, ATI convertor, REF headers 1 7/8-2 1/8 with merge collectors, Aerospace brake system front and rear (dual caliper setup on rear), Weld AlumaStars front and back with Goodyear tires, Kirkey aluminum seats with black vinyl covers, Braille 21lb battery, etc..
390 motor has T&D Sportsman setup, Kuntz did the Edelbrock heads, hollow stem valves, beehive springs etc., Redline camshaft with Trend Perf lifters etc.. C4 transmission is torrington bearing throughout, aluminum drums, deep pan, 2.75 first gear. Third members Nodular and Aluminum 4.63-5.29, R&P sets, Moser 35 spline rifle drilled profile milled axles and rear wheels are 4 3/4 BC as are the rear rotors.... Most all is new or never run, just built it and its been in my shop. Anything that has to do with a D/SA-F/SA 67 Fairlane Stocker is forsale from this car so if i did not list it, just ask and I probably have it. 210-three seven three-40zero4 with any questions. Thanks for looking RJ Sledge Last edited by RJ Sledge; 02-17-2018 at 01:34 PM. |
Liked 4 Times in 4 Posts
rj, any good shocks that also fit 68 mustang?
Ron I sent you a private message, respond by PM
RJ |
Liked 33 Times in 16 Posts
Where are you located?
Rich Taylor I/SA - 321 |
RJ I left you a message on the New FE forum, interested in the C4 bell, the brakes, and was all so wondering if you have any extra of the standard trim for a 67 Fairlane post car
Thanks |
Liked 166 Times in 46 Posts
Hey Are Jay, would you happen to have one of those original Canadian built C4 transmissions that came in Mercury pickups?
Liked 11,028 Times in 2,266 Posts
Well said Jim
Liked 880 Times in 311 Posts
No Cimo, I don't think he has any of the Mercury Truck parts, but Are Jay has a shelf full of those Shelby rubber lobed camshafts for FE Fords.... You know the kind that check right on the spec then when you rev it up they get more lift and duration.
Adger Smith (Former SS) |
