Old 06-04-2014, 05:33 PM   #1
Slickfoot
Liked 2 Times in 2 Posts
Default Park safety switch wiring
I am changing my 89 fox over to a C4 from a 5 speed. I'm down to wiring the park safety switch. I thought I would use the wiring from the clutch interlock, after unpluging the conneter I see that it has 3 wires all blue with a red strip and just two terminals in the plug. What going on here? and what's all the outhers in the 2nd plug on the clutch? Help!
thanks
slickfoot 3955
Slickfoot is offline   Reply With Quote
Old 06-04-2014, 08:17 PM   #2
partsbob67
Liked 79 Times in 11 Posts
Default Re: Park safety switch wiring
mine is an automatic car. the connector under the dash has a jumper plug from the factory that just loops from one wire to the other. perfect spot to wire in your safety switch. not sure where the other wires go or what they're for.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 06-04-2014, 10:00 PM   #3
George Wright
George Wright's Avatar
Liked 408 Times in 35 Posts
One switch allows you to engage the starter when the clutch is pushed all the way to the floor. the other switch engages just as you begin to push the clutch, it shuts off the cruise control.
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
