Old 04-16-2007, 03:59 PM   #1
Jeff Teuton
Liked 325 Times in 50 Posts
Default Stacker Tires
Almost all the stacker trailers have Goodyear Model 614 235/85/16 G rated (14 ply) tires which have been know to blow out at any time. I have made arrangements with Superior Tire which is about 3 or 4 miles from No Problem to have some of these in stock should the need arise. If for some reason, they cannot have any for the race, I have a couple of new tires I will bring to help someone if they need it. The track knows how to get in touch with me if I am not there when you get there. Jeff
Jeff Teuton 4022 STK
Old 04-16-2007, 05:24 PM   #2
sammy christian
Default
just a tip in case anyone didn't know- make sure your stacker has the REAL brass or steel valve stems. most blown tires of that type are caused by losing the rubber valve stem-not usually the tires fault. only takes about halfa mile to lose the tire with no air on trailers that heavy.
sammy christian is offline   Reply With Quote
Old 04-17-2007, 04:13 PM   #3
Jeff Teuton
Default
Looks like Goodyear has mostly back orders on those tires. There are 10 being shipped to Paincortville (Surburb of No Problem), but they might not make it this week. I am trying for other brands at this time.
Old 04-17-2007, 04:21 PM   #4
John Kelley
Default
"Paincortville (Surburb of No Problem),"
I think I figured this out.....It's BELLE ROSE if you WIN
And PAINCOURTVILLE if you LOSE !!!! :->
[:-good-:][:-grin-:]
John Kelley is offline   Reply With Quote
Old 04-18-2007, 12:41 AM   #5
Lynn A McCarty
Lynn A McCarty's Avatar
Default
Another item about stacker tires. Yes Jeff, we had trouble with our G rated tires, but found that with the stiff sidewalls and two HEAVY superstock Pontiacs, we found that trying to turn the tri-axle trailer too sharp was responsible for tearing up the tires.
Taking wide turns and not whipping the trailer too quickly increased tire life significantly. Those tires with 110llbs of air and 14plys have no give. Just like the girl I dated in High School for about 2 weeks.
Lynn
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
