Old 08-05-2013, 06:19 PM   #1
428tom
Default Fox body mustang rear spring?
Wondering what most guys are using for a rear coil spring in a fox body mustang stocker with a 30x9 radial?
428tom is offline   Reply With Quote
Old 08-05-2013, 07:28 PM   #2
SSDiv6
Default Re: Fox body mustang rear spring?
Moroso or Laurel Mountain.
Old 08-05-2013, 07:37 PM   #3
Rory McNeil
Liked 1,104 Times in 302 Posts
My 85 is a carbed stick car, with bias ply slicks, but I am just using factory V8 GT rear springs, with Air Lift bags inside.I tried the Morosos, but they seemed too weak, at least with the stick. .
NHRA 6390 STK
M/S 85 Mustang
Old 08-05-2013, 09:08 PM   #4
partsbob67
Liked 79 Times in 11 Posts
I used the ones from steeda. worked very well.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 08-05-2013, 09:16 PM   #5
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
I had the moroso rear springs, car was way too low, 95 gt moog springs might bewhat you want...I think
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 08-05-2013, 10:09 PM   #6
stang321
stang321's Avatar
I have eibach drag launch with an air bag in the right rear. They work well but will only fit a 28 in tire
stang321 is offline   Reply With Quote
Old 08-05-2013, 10:29 PM   #7
Notch1320
I ran stock, uncut GT rear springs in mine.
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 08-05-2013, 10:58 PM   #8
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Lotsa people using stock v8 rear springs with an air bag. FOMOCO brand not aftermarket replacements. Cut one coil out to set the ride height if you want it a little lower and you are all set.
Mitch Beri- The Motor City
Old 08-05-2013, 11:11 PM   #9
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Good shocks is the key, the factory GT springs work. AFCO double adj. No air bags.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 08-06-2013, 09:12 PM   #10
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
I use the 1988 GT/Hatch progressive spring. Generally get about 4 years out of them before they get weak thats running it at 3400 lbs, and will knock the rear bumper off if it didnt have wheelie bars.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
