Old 02-22-2013, 01:15 PM   #1
pontiacchuck
Default turbo 350
is there one trans better then other turbo 350 some one told me some have more clutch disc
pontiacchuck is offline   Reply With Quote
Old 02-22-2013, 07:17 PM   #2
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
Default Re: turbo 350
check your personal messages
jim powers is offline   Reply With Quote
Old 02-22-2013, 10:45 PM   #3
If you are talking about the direct clutch..Yes .Some models have an extra clutch or two.
You can just machine the piston and add clutches , if you need them.
We can't begin to make that guess, because we have no idea what you're working on.
Old 02-22-2013, 10:56 PM   #4
As you can imagine, light duty, 4 , 6 cylinder cars would have less. You should be able to figure that out by the code on the tag, if you're shopping cores.
Old 02-23-2013, 02:03 PM   #5
pontiacchuck
what code should i look for thank you chuck
Old 02-23-2013, 06:22 PM   #6
art leong
Chuck if you are talking about a turbocharged car. I would be careful of the lightweight tricks. Many things that are done to fairly high power V8's won't stand the rapid torque of a quick spooling turbo.
Art Leong 2095 SS
Old 02-23-2013, 11:19 PM   #7
Like I was saying..It doesn't much matter..The later ones had more Torrington bearings .
If I was going to build a good one, I'd use parts from a T350 , T 250, and a 700R4 anyway
Depends on the application how many clutches you need ,where.
Can't help you any further without that.
Old 02-24-2013, 09:33 AM   #8
pontiacchuck
et bracket car 80 pontiac grand prix 455 pontiac mild built 9 in ford rear end 3:70 gears 3200 with driver 3000 stall
Old 02-24-2013, 12:54 PM   #9
In that case ,I'd build a 350C , 9 or 10 " conv. with a lock up clutch in it, 3.55 gears.
No need for the 700 and 250 parts...You can put and extra clutch in the direct if it makes you happy.
Full feed the direct drum, raise the pressure A LITTLE , hardened intermediate sprag race, (a must have), block the accumulators and the low gear blow off valve, drill a out few holes in the separator plate, and you got it.
