Old 11-09-2012, 11:30 AM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Default GM steel dually wheels---center bore question
AFTER I bought these sight unseen on ebay---ok I know---16" gm oem steel wheels----I bought a pair of these.........the bolt pattern is the same, the width is correct, the diameter is correct BUT the center bore on one wheel is slightly larger than the stock wheel......does that really matter in any way as long as the bolt pattern is correct ??? After some research I found out the center bore got larger after 2001, obviously I have two wheels each from a different era. Does the center bore carry any load ???
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
