Old 04-18-2012, 08:09 PM   #1
Stewart Way
Liked 70 Times in 22 Posts
Default cummins 5.9 fuel line leaks
I have a 2005 2500 dodge diesel. For the second time it has developed a fatigue crack in a hard line from the fuel rail to the injector. This one was on #4. The line is about 7" long ($86) with a clamp in the middle. Not sure which one it was the first time because it quit in the middle of traffic and had to be towed and fixed under warranty.
I have looked on the internet and have found this is a common problem. They crack right behind the end of the ferrel at the injector end. Enough that some guys are keeping an extra one in the truck and the 2 wrenches to change it.
Anyone seen this problem and or know of a solution?
Stewart Way 2424 SS
Old 04-19-2012, 12:28 AM   #2
Run to Rund
Liked 56 Times in 29 Posts
Default Re: cummins 5.9 fuel line leaks
Tighten the new one carefully so the support/vibration bracket has no stress on the line. #6 occasionally cracked until a support bracket was added around 2005 or so; it goes to the engine lift bracket bolt that is converted to a bolt/stud. #4 is the most common one to fail for some reason. Get it from Cummins for about $25-30.
Old 05-09-2012, 09:47 AM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Question Re: cummins 5.9 fuel line leaks
I have an '05 2500 w/ Cummins 5.9. I have all of 44,000 miles on it, mostly towing, should I be worried? I've never heard of this! Jim
Old 05-09-2012, 01:09 PM   #4
Run to Rund
I worry a lot about a lot of things so I carry spare lines and a 3/4" open end wrench. I wouldn't say the failure is common but it happens enough to be cautious, especially if you go on long trips, etc. You can't just continue running with a cracked line as it is under rail pressure all the time. Rail pressure does go up with more accelerator pedal, from about 5000 psi at idle to a max of about 23,000 psi.
Old 05-09-2012, 11:28 PM   #5
Jim Wahl
Jim Wahl's Avatar
Exclamation Re: cummins 5.9 fuel line leaks
Here ya go:
http://www.dieselbombers.com/5-9-lit...ctor-line.html
Old 05-10-2012, 08:57 AM   #6
FED 387
Liked 335 Times in 182 Posts
what years are affected??? are any immune or is it a problem that any 5.9 cummins might have??? my son has a 2008
Old 05-10-2012, 11:23 AM   #7
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi All,
Tese are a great resource for information on all Dodge Diesels.....
http://www.dieseltruckresource.com/dev/index.php
http://www.cumminsforum.com/forum/
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 05-10-2012, 01:37 PM   #8
Run to Rund
The original club and its website are still very good:
www.turbodieselregister.com
Old 05-10-2012, 09:45 PM   #9
Bob Mulry
Bob Mulry's Avatar
I used the TDR forum for years and when they started to charge $35.00 a year to subscribe, I found my information at the free sites.
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 05-11-2012, 08:08 AM   #10
cad
cad's Avatar
Liked 93 Times in 52 Posts
I haven't heard of any issues with the 6.7, and thankfully I've only had 1 injector fail on my 06 5.9, which filled the engine with diesel .
Clark
