Liked 199 Times in 52 Posts
2010 COBRA JET 352
Win class or any heads-up race! Qualify #1! This car will run 1.50 under in E/SA at over 100lbs. heavy, with 6 quarts of XP3, timing backed down, and shifting 500 rpm early! No Ice or chiller needed. If you let it run at its peak, it can go more than 1.70 under. You can also set this car up to run at 1.00 under, 1.10 under, 1.15 under or whatever you like in minutes! #1 qualifier at the Infineon NHRA Divisional and National events. Qualified #6 at Vegas to avoid the AHFS trigger. Only 17 passes made since new. This car was built from a brand new 2010 Mustang and 100% legal for NHRA Stock or Super Stock. Completed in May 2011. Only the right parts and the best parts from the best manufacturers, chassis, engine and transmission builders were used. This car will stay at the top of its class longer than the LT1’s and LS1’s! Complete build sheet available to qualified buyers wow Kevin |
