Old 11-28-2011, 08:22 AM   #1
danny waters sr
danny waters sr's Avatar
Question Cam # help ????
I have a Lunati small block chevy roller cam out of the superstocker and cannot find out what it is by the #'s on it. Can anyone help please.......There is one place with something on the end of cam that has been grind off. other than that here are the #'s on the end of cam below...........
119896
8C2A
Lunati....
Just need the lift and specs if possible////Thanks
Old 11-28-2011, 01:52 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 321 Times in 109 Posts
Default Re: Cam # help ????
Have you tried Lunati? If can't find out can have checked on cam doctor. You can measure lobe lift and maybe able to narrow down what lobes they are.
In case you don't know measure lobe both directions and difference is the lobe lift then multiply rocker ratio for lift @ valve.
Mike Taylor 3601
Old 11-28-2011, 07:11 PM   #3
danny waters sr
Mike Taylor 3601
I went on line at Lunati and could not find it.... I was hoping someone had one like it on here and could tell me what it was.....
Thanks for the info
Old 11-28-2011, 07:29 PM   #4
That appears to be a serial number, you'll probably have to call Lunati, and hope they still have the records.
