Old 10-02-2011, 09:18 PM   #1
jnwoods
Default rotor & hat
What would cause the hat to be sheared from the rotor. The hat is hexbolted to the rotor. It didn't shear at the bolts, it sheared at the bend. Is this common? Wilwood hat with 2.12 inch offset & solid Aerospace rotor. Would you replace both sides?
jnwoods is offline   Reply With Quote
