Old 06-20-2011, 11:37 AM   #1
Joe Grippo
Liked 41 Times in 4 Posts
Default What do you think it could be?
So, looking for some opinions on this situation. I had the race car out to the track finally on Friday for some check out passes before the regular weekend races. I pull into the water box and do my burn out and the car sounds like its laboring a bit as it usually it has a nice high pitch scream…ok. So I go ahead and stage up, footbrake it to my normal 4000 rpm and the light turns green and I swap feet matting the gas expecting to see the sky but no…the rpm on the tach goes up but the car just drives away like its pulling away from a stop sign. I drove easy down the track and when I shifted it seemed firm and crisp as normal. I have some ideas but I am looking for opinions to confirm my suspicions. For reference it’s a 10.40 bracket car with a 625 hp SBF, C4 with an 8” converter with a 4500 stall. Trans was freshened in ’09 and the TC was flushed out at the same time. Fluid level and color are normal with no burnt smell. Thoughts?
I don't know if this needs to go to the bracket section or not...
Joe Grippo is offline   Reply With Quote
Old 06-20-2011, 11:47 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,956 Times in 591 Posts
Default Re: What do you think it could be?
sounds like something went sour in the engine. Spun bearings or possibly a broken rocker arm, valve springs. I would pull the filter and check for metal in the oil.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 06-20-2011, 12:10 PM   #3
Phillip marvetz
Phillip marvetz's Avatar
Sounds like a broken sprag.
2009 V/SA Record Holder
Old 06-20-2011, 12:13 PM   #4
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Sprag in the converter for sure
Pedigo Perf is offline   Reply With Quote
Old 06-20-2011, 02:36 PM   #5
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
another stating it's the sprag
Old 06-20-2011, 02:52 PM   #6
Joe Grippo
Thanks everyone..That was my though and it seems to be the general consensus. Guess I'll pull it out...
Lots of experience around here, thanks again for letting me pick your brains.
Old 06-20-2011, 11:02 PM   #7
Chad Rhodes
sprag
Chad Rhodes 2113 I/SA
Old 06-21-2011, 03:08 PM   #8
Earle Holt
Liked 4 Times in 1 Post
Put a stick in it Joe!
Earle Holt 1055 Stock
Earle Holt is offline   Reply With Quote
Old 06-21-2011, 03:17 PM   #9
Joe Grippo
Hey Earl, I never thought about that! Got any spare G-Forces laying around?
Old 06-21-2011, 10:36 PM   #10
HR9121
HR9121's Avatar
Just to make you feel better informed one more time its the sprag.. just went through the same thing two weeks ago car acted identical to what you are saying.
James Williamson
W200 J/SA. SS/JA
