Old 06-19-2011, 01:35 PM   #1
TinSoldier 3215
Liked 6 Times in 5 Posts
Default MSD Distributor?
MSD Distributor is it better to have a steel or brass gear on the end? We had the car slow down 2 years and find the gear was all chewed up. I can't recall what the engine builder put on or if him put a new one on. I was just wanting to know if when i pull the distributor out and find that the gear is chewed up what could be happen to it? Happy Father's Day to the DADS!! I'm almost sure that's what the deal is. Gear bad..
TinSoldier 3215 is offline   Reply With Quote
Old 06-19-2011, 02:30 PM   #2
Liked 1,909 Times in 427 Posts
Default Re: MSD Distributor?
I use the Comp Cams composite gear on my MSD/Chevrolet distributors. Even at 8500 RPM with 75-80 psi oil pressure they hold up very well, and never damage a camshaft gear.
Old 06-22-2011, 03:56 PM   #3
John Lang
Liked 6 Times in 2 Posts
Thumbs up Re: MSD Distributor?
I've always been told that if you have a Steel cam as in a Roller, then you better use a dist gear made of a bronze or composite ! With a cast cam ,such as a hyd, or solid flat tappet cam use a stock gear with no problems ! This has always been the rule on my Mopars !,,,,,,,,,,John
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
Old 06-23-2011, 09:03 PM   #4
TinSoldier 3215
Thanks guys for the help, pulled distributor and found the 3 teeth was gone,put a new brass gear!!
