Old 03-14-2011, 01:16 AM   #1
Marvin Robinson
Marvin Robinson's Avatar
Default BB Olds bearings
Is anyone aware of availability of a .050 under bearing for the 455 Olds rods?? If not, is there a suitable undersize that I can grind my crank to and use a different bearing??? Thanks.
Marvin Robinson
3188 STK/SS
Marvin Robinson is offline   Reply With Quote
Old 03-14-2011, 11:24 AM   #2
Liked 1,874 Times in 422 Posts
Default Re: BB Olds bearings
Marvin, what are you trying to do? Repair a bad journal?
Old 03-14-2011, 04:43 PM   #3
Marvin Robinson
You got it, #5 rod took the journal down .004 when it spun, and the crank is already .040 under (.013 offset). I'm getting a lot of negatives trying to get the crank welded..... if I have to replace it, can I use the Eagle cast crank in stock??
Marvin Robinson
3188 STK/SS
Old 03-14-2011, 06:46 PM   #4
Nope. Aftermarket crankshafts are not legal in Stock. I know Olds cranks are getting hard to find. At least good ones are. So are blocks.
Old 03-14-2011, 07:32 PM   #5
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Do you really need .013 on a 455 Olds??? HAHA If it were SS you could offset grind a 425 crank and use 454 bearings.
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 03-14-2011, 07:36 PM   #6
Marvin Robinson
I don't see any real advantage to offsetting by .013, but that's the way the motor was when I bought the car. If the crank needs to be turned .010 or .020 under, might as well get the minuscule stroke advantage, too. (Note: in the Olds, most stock blocks have the pistons about .030 down in the hole, the offset will reduce the amount you have to deck the block)
Marvin Robinson
3188 STK/SS
Old 03-15-2011, 08:04 AM   #7
Jim Kaekel
Liked 535 Times in 110 Posts
Marvin: When the crank is stroked .013", it is also "indexed" as well, insuring that the rod throws are truly 90° apart. It shouldn't be too hard finding a suitable replacement crank, I'm not hoarding all of them.
Jim Kaekel 3836 STK
Old 03-15-2011, 11:08 AM   #8
Marvin Robinson
Good point, thanx for the info, Jim. I think I've got a line on a couple spares (I want to build a spare short block, too. Shure would be nice to just be able to buy an Eagle cast crank.
Marvin Robinson
3188 STK/SS
