Liked 14 Times in 11 Posts
Please educate me,
IF I was to run my 383 Duster as a SSGT car, the long block parts needs to be legal for the year claimed (70 or 71), the correct carb must be used, but what about the intake manifold? Aftermarket OK? Other than that, cam and pistons #'s must be what is in the tech sheets? As you can see it's pretty boring around here this morning.
Phil Saran Parker, Colorado |
Liked 18 Times in 8 Posts
I thought it was any intake (right number of carbs in your case as claimed 1 4B ) that fits under your flat hood. But check futher...I'm new at this. LOL
Wade Mahaffey |
Liked 327 Times in 121 Posts
It's a Superstock motor put in a different year body. I'm building the same motor, it's rated at 304 HP for GT. In a Duster you'll fall higher than GT/HA so you'll need a full certified cage for starts.
Liked 325 Times in 50 Posts
Pistons can have notches in SS I think and I think there was an available scoop in a 74, so a live scoop is ok since the 383 had a scoop.
Jeff Teuton 4022 STK Last edited by Jeff Teuton; 01-01-2011 at 05:53 PM. Reason: added something |
#5 | |
Any valve train or intake (relative to OEM configuration), porting within specs, and a few other items allowed. Consult rulebook. SS is the next level above Stock.
Jeff Lee 7494 D/S '70 AMX |
#6 | |
highest weight of a 360 Duster at 3400lbs so it should fall into SSGT/FA, but maybe I did it wrong?
Enter shipping weight for chosen body style -> 3242.00 lbs
Enter factored HP for chosen engine -> 300.00 HP Enter A for automatic, M for stick -> a A or M CALCULATED VALUES: Minus 250lb permitted shipping weight adjustment 2992.00 Plus 250lb permitted shipping weight adjustment 3492.00 "Natural" class -> GT/FA Wgt Break-> 10.81 GT/F Lowest legal class -> GT/DA Wgt Break-> 9.97 GT/D Highest legal class -> GT/HA Wgt Break-> 11.64 GT/H Class GT/DA GT/EA GT/FA GT/GA GT/HA Index 10.50 10.65 10.80 10.90 11.05 0.3 under index 10.20 10.35 10.50 10.60 10.75 0.5 under index 10.00 10.15 10.30 10.40 10.55 0.8 under index 9.70 9.85 10.00 10.10 10.25 MINIMUM Weight 2992.00 3000.00 3150.00 3300.00 3450.00 MINIMUM Race Weight incl. 170 lbs for driver 3162.00 3170.00 3320.00 3470.00 3620.00 Estimated HP required for E.T. #1 (SEE NOTE 1) Index 516.9 496.7 500.1 509.6 511.4 0.3 under index 563.9 541.2 544.2 554.1 555.4 0.5 under index 598.4 573.8 576.5 586.7 587.6 0.8 under index 655.7 627.8 630.0 640.6 640.7 "NOTE 1: Flywheel HP requirement to achieve E.T. based on the Chrysler estimation equation: HP = Weight * 200/(ET^3) using the Minimum Race Weight." Estimated HP required for E.T. #2 (SEE NOTE 2) Index 498.8 479.3 482.6 491.8 493.5 0.3 under index 544.1 522.2 525.2 534.8 536.0 0.5 under index 577.5 553.7 556.4 566.2 567.0 0.8 under index 632.7 605.9 608.0 618.2 618.3 "NOTE 2: Flywheel HP requirement to achieve E.T. based on uniform acceleration equation: HP = Weight * 193/(ET^3) using the Minimum Race Weight."
Thank you Jeff Lee, now all I need is for the Lotto numbers to fall my way....
Liked 99 Times in 49 Posts
Liked 11 Times in 8 Posts
I thought for Super Stock that you can use any intake manifold as long as it is configured the same as the original manifold.
