Old 08-26-2010, 02:03 AM   #1
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Cool Ihra stock car classification guide
Can someone tell me where I can view a stock car classification guide for IHRA. I'm planning on running a new car (85 Camaro) at the Crandall pro-am. As I don't have a 305 engine at this time I was planning on putting a 71 350/270 in it to run in the stock gt class.My problem is I don't know what power to weight factor to use. The Nhra book doesn't list a 85 Camaro with a 350/270. I don't know whether to use the factor for my Nova (11.36) or what to use. HELP!
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 08-26-2010, 06:30 AM   #2
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Default Re: Ihra stock car classification guide
Use the 305 engine factor to get the shipping wt of your Camaro then use your 350 combo HP factor to get the GT class.
Old 08-26-2010, 07:31 AM   #3
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
I was told they use the NHRA guidlines......
Mack Reeves
2377 STOCK & SUPER STOCK
Old 08-26-2010, 08:30 AM   #4
X-TECH MAN
Banned
Smile Re: Ihra stock car classification guide
They do in MOST cases. Some HP factors are different (minor rating difference in most cases) so the shipping wt/class factor has to be re-calculated when running a combo as a natural NHRA style class car. When building a GT or Crate Motored combo you just use the shipping wts (same/same) to figure the class. The shipping wt never changes more than a couple of pounds no matter the HP factor. Just be sure to use the small block shipping wt for a small block combo and the big block shipping wt for a big block combo.
Old 08-26-2010, 01:05 PM   #5
Bill Bogues
Thanks for the reply: I was a little lost on this one.
Old 08-26-2010, 05:59 PM   #6
Mike Savelle
Liked 7 Times in 5 Posts
Cool Re: Ihra stock car classification guide
With the 350/270 you will be in GT/D . @ 11.00 to 11.99 lbs per Hp. When i ran that class the minimum weight was 11 x 270 plus 170 = 3170 , not sure if you can get your car that light. Mike
Mike Savelle is offline   Reply With Quote
