Old 07-13-2010, 03:49 PM   #1
ken robinson
Liked 225 Times in 88 Posts
Default Is my brake porportioning valve bad
Has my 67 camaro brake porportioning valve gone bad ? All of the 4 drum brakes work and hold strong and release fine .The main problem is with line lock it just can't lock down front brakes . Put new hurst line lock in end of last year , just due to the old hurst line loc soleniod started to stick/died . It just seams like it holds at half the pressure , compaired to if you just push on the pedal and try to turn the wheels . The line lock is get full 12vdc . All line connected wright in and out . Its the only thing left . Anybody run in to this ? Ken R.
