Old 09-04-2009, 03:17 PM   #1
Stephen Hughes
Default Titanium Valves
Anybody here have any A-B results of switching to Titanium Valves in your typical 900-1000 hp Big Block Chevy? Any performance gains to be had from making the switch? I can't imagine there would be any downside other than cost, but if there is, what is it?
Stephen Hughes is offline   Reply With Quote
Old 09-05-2009, 01:52 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Titanium Valves
Steve, I put in Manley stainless intake valves in my 565 this year cause the repair budget on the motor ran a little high and funds were a little tight. .....I normally only run titanium intake valve,as I broke several stainless intake valves over the years ,but never experenced exhaust breakage. .........So far this year, the only difference I've noticed is that the intake springs are back to loosing pressure faster than with the titanium valves.........From past experiances ,I only plan to run the stainless valves one season aand replace them. .......I' am convinced the biggest benefits from titanium valves on a BBC ,are seen on the intake valve. .....Lifter life and especially intake valve spring life are greatly improved., plus ,I have never experienced a catrostropic failure with the titanium valves. [not saying it can't and dos'nt happen. ,Just my experience} ......
Old 09-15-2009, 04:02 PM   #3
63corvette
Liked 359 Times in 103 Posts
I agree with Tom. The best thing about the Titanium valves is the extended spring and lifter life. If you run a very radical cam you should use the Titanium valves.
I use them in both intake and exhaust on a 1000 HP 565 cu in super gas car.
For me it is just added insurance.
My 2 Cents
63corvette is offline   Reply With Quote
