Old 03-09-2009, 10:07 PM   #1
trmnatr
Default GM 010/020 Blocks
How much HP have you Super Stock guys pushed out of 010/020 blocks filled with hardblok to bottom of waterpump with ARP main studs and factory caps in a 327 and in a 350 ?
If you could answer these 3 below that would sum it up
HP ?
RPM ?
CID ?
Also, do you guys know where to find any 3.25" stroke GM cranks ? Large or small journal, if so can you please post a link
Thanks in advance
trmnatr is offline   Reply With Quote
Old 03-10-2009, 09:16 PM   #2
Aaron Keown
Aaron Keown's Avatar
Default Re: GM 010/020 Blocks
People have made 600+ horsepower and ran 9000 r.p.m. with good rock blocks,good being the key word there.The thing that sucks about rock blocks the most is you really don't know if you have a good one until you build a high performance engine with one and take the chance of knocking the side out of it..Yes you can use a sonic checker and all that but it still no guarantee.A reasonable number is probably 500-550 h.p and about 8000 r.p.m. I would not go more than 4.070 on the bore size on the block you are talking about.I have also seen brand new engines built with rock blocks knock the side out ,so needless to say I am not really a fan of them.With the price of after market blocks as reasonable as they are any more I really don't see much point in using one unless it is for a budget build.Also,what kind of crankshaft are you looking for,after market or a factory core?
Aaron Keown is offline   Reply With Quote
Old 03-10-2009, 09:26 PM   #3
trmnatr
GM Steel Crank, small or large journal
Yes, this one dont want to put a ton of money into
Bore will only be 4.030"
Will be sonic checked
Will be filled with hardblok
Will have head/main studs
Old 03-11-2009, 02:37 AM   #4
trmnatr
these are the pistons we are running. They are 329gram piston, 88gram wrist pin, .043" .043" 3mm ring pack with gas ports, accumulator grooves and anti detonation grooves
Old 03-11-2009, 07:34 AM   #5
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
TRMNATR,
Email me direct. I've got several cranks.
Terry
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 03-11-2009, 10:04 AM   #6
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
best stock small blocks. know of a few 9 second cars built before the ease of availability of good quality aftermarket blocks. friend has a few of these 010 over 020 blocks sitting. the blocks I know of took a major beating.
chris ok is offline   Reply With Quote
Old 03-11-2009, 10:29 AM   #7
trmnatr
Hi Chris,
Thanks for the information. I have not really used a ton of these blocks for race engines, a few but not at this kind of rpm
I usually use a 2 bolt main, filled with hardblok with Milodon splayed main caps (which i thought about on this one)
Being this is what i would call more of a budget build i thought about using the domed pistons which are 480gram, that would allow me to keep the 329gram pistons to save a few $ for a super light aluminum rod (about 435gram rod)
Im gonna use my Comp cam which is HXL intake lobe and RZ exhaust lobe. 307/317 @.020" 278/284 @.050" 201/197 @.200" .726"/.660" with 1.6/1.5 rockers 106 degree lobe seperation
Top View
Skirt View
Underside View
Old 03-11-2009, 10:31 AM   #8
trmnatr
Originally Posted by Terry Cain View Post
TRMNATR,
Terry
Terry,
Thanks, message sent
